Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Infill T3
Old 06-09-2007, 03:31 PM   #1
TV failed to initialize
When I try to run the TV in SD, it tells me that the TV Tuner failed to initialize and that the hardware is not present. (SD on Infill T3)
Is there a driver I am supposed to use for the TV tuner?
TheJuggler is offline   Reply With Quote
Old 06-10-2007, 02:18 AM   #2
I remember having that problem when I used to use StreetDeck. It was an error where the button menu doesn't work. But if you use the gesture "T" for TV it should work. At least it did for me.
Infill T3 with Infill Station
2007 Hyundai Sonata
irdrive is offline   Reply With Quote
Old 06-10-2007, 09:24 PM   #3
I got it figured out somehow. I tried reinstalling the capture driver that was provided. Not sure why I had to do that again, but maybe some other driver need to be installed first.
Works now. Fairly good reception too. (at least on a couple of the local channels.)
Thanks for the insight!
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 03:29 PM
