Shutdown options?
I have a few questions on Shutdown options on the T3.
What is the ideal setup? The Streetdeck manual does not explain the options in the "Shutdown Options" menu it only has the screenshot of them..
Should I set the default Shutdown option to "Standby"? (Is there a Hibernate option)
I cannot see a hibernate option on the T3 even in the Windows XP Power properties, how do I enable the Hibernation option?
I want the Streetdeck to Hibernate the T3 when I turn off the ignition in the car, and then shutdown the T3. What settings should I use to achieve this?
When I turn off the ignition and pull the key while the T3 is turning off does this pull the power to the T3 and kill it or does it still go through a proper shutdown?
