Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Infill T3
Old 06-20-2007, 04:30 PM   #1
isamfarina is an unknown quantity at this point
screen blinks
When endeder the lights of the car, the screen blinks and loses something of brightness. As I can solve this? The truth is that he is annoying when I lead at night.
isamfarina is offline   Reply With Quote
Old 06-20-2007, 05:08 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
what?!
Are you trying to say that when you turn on your headlights, your screen blinks and dims? If so, your wiring is unsufficient. Run a better cable.
Old 06-20-2007, 07:16 PM   #3
jabz is an unknown quantity at this point
Hmm I think he is trying to say that when the headlights are turned on the display dims, and he doesn't like it?
This is normal behavior when you have both the ILL wires hooked up to your car Harness. Not sure if there is a setting to stop it, or you could just disconnect the ILL wire from the TOP unit, if you leave the ILL wire from the bottom unit connected your button backlights will still work when turning on the car headlights
jabz is offline   Reply With Quote
Old 06-21-2007, 09:24 AM   #4
sharpmat007's Avatar
sharpmat007 is an unknown quantity at this point
Dimmer lead incompatibility
Your dimmer lead is not compatible with the infill. I had the same problem...connect to a lead that doesnt have varying voltage. I have two dimmer leads in mine, one is straight 12v the other is adjustable based on the dimmer knob. Use the one that is straight 12v...if you dont have a lead like that you can tap into your headlight switch/knob.
Another option...which someone else has posted you can put a relay on the dimmer lead so that the lights on the infill will either be on or off, but not inbetween voltages.
The other option you have is to have the lights come on all the time and hook your dimmer leads up to the accessory power. This will also dim the display though.
Remember you can also hold the mode button to dim the display.
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
sharpmat007 is offline   Reply With Quote
The absolute easiest way to make a windows boot screen..... polo6979 Newbie 14 09-11-2008 04:14 PM
Constantly removing the screen 7" lilliput advice steveb LCD/Display 10 04-17-2007 11:56 AM
Cracked Touch Screen! bmather9 LCD/Display 5 04-17-2007 05:31 AM
Non-VGA screen to VGA xxMIKExx LCD/Display 13 04-10-2007 10:18 PM
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 01:20 AM
