Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Infill T3
Old 07-02-2007, 11:49 PM   #1
TheJuggler is an unknown quantity at this point
Lost Front Left Channel
I've had my T3 installed for about a month now.
Recently I've had an issue that the front left channel doesn't put out any sound. I've narrowed it down to the unit itself and not the amp or wires. Front right, and rears still work fine.
Everything looks connected (even inside the unit) and I don't see any breaks in the cable.
Anyone have any suggestions on a fix for this?
TheJuggler is offline   Reply With Quote
Old 07-03-2007, 10:19 AM   #2
ScotLarsen is an unknown quantity at this point
Are you sure it's not Streetdeck? Have you tried the onboard sound card audio tools that come on the SD CD?
Scot
ScotLarsen is offline   Reply With Quote
Old 07-03-2007, 10:30 AM   #3
sharpmat007's Avatar
sharpmat007 is an unknown quantity at this point
Agree... you should test using the Via AudioDeck panel.
YOU MUST CLOSE STREETDECK COMPLETELY! The test wont be accurate if you don't.
If it still does not work, you may be able to narrow down where the failure is.
- Swap the left and right rca jacks that go between the upper and lower unit. See if the problem follows to the right channel not working. If it does, you know its not the amplifier and might be something wrong with your rca connection.
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
sharpmat007 is offline   Reply With Quote
Old 07-03-2007, 02:31 PM   #4
Scot
Yes. I've tested it thouroughly. Vinyl Deck has a tool that lets you test each speaker independently (in 2 channel, 4 channel or 6 channel). I can hook the front left RCA cable up to any of the RCA cables running to my speakers. I get nothing. I can hook up any of the other channels up to any of the other speakers (including that front left one) and they all work. I checked all the sounds setting in windows to make sure that the balance or fade wan't set off that corner. I even removed and reinstalled the Vinyl Drivers.
I do have the ability to set my amp to use only the right channel for both front speakers, but if I do this, I lose out on stereo sound.
I was also looking for an add-on USB audio card, but I can't seem to find any that provide 6 channel sound.
Thanks for the help guys!
Old 07-03-2007, 02:36 PM   #5
I'm not using the built-in amp, so I don't have the cables running to the upper portion of the T3. I'm also sure that SD isn't running. I double checked in the task manager. The RCA cable physically looks fine, I've even followed it back inside the unit. The connection looks good, although I don't have a multimeter to test. I don't see anything wrong ont he motherboard either.
Is there a place where you can buy a new motherboard for the T3? Or find someone selling a broken T3 for parts?
Old 07-03-2007, 03:06 PM   #6
Hmmm...it was my understanding that you MUST connect the cables between both units. I used an rca splitter so I can hook up the rear and front channels to an external amplifier. I know its required for the internal amp, but I thought it also directed the sound from the TV and radio back into the windows mixer.
Are you sure you have your rca wires connected properly? It should be straight forward, with the exception of the word "real" is supposed to read "rear" on the wire label.
If you really think you need a new system board you may ask mp3car if they have a scrap unit...other than that you would have to go to maxan in korea to get one.
Old 07-03-2007, 05:26 PM   #7
I connected the Left and Right audio outs and video out cables from the TV unit to the lower unit. These are required to provide TV and radio sound to the lower unit.
The only reason to connect the Left/ Right Front and Rears back to the top unit is if you intend to connect to speakers using the speaker wires instead of to an external amp. Otherwise, those RCAs connect directly to your amp. You'll see this listed in the installation instructions.
What sucks is that it was previously all working fine, with the exception of some alternator whine. I took it in to Best Buy (where I had the speakers installed) to check on that. The looked at it for about 20 minutes and then said they needed to set up another inspection appointment because it was going to take longer. I then noticed that they had swapped around the RCA cables on my amp and switched the amp into Mono mode. When I switched it all back, the Front left channel of the T3 no longer worked.
I just did a fresh install of Windows, hoping that it was just some driver issue. Still no luck. It looks like it really is a hardware issue. I may check with a PC repair shop can help.
I appreciate the help!
Old 08-19-2007, 11:49 PM   #8
Okay, so I don't know what the heck is wrong with my T3, but now I've lost audio on all 4 channels. They don't work in SD or in Windows. I've connected other devices to my amp and the speakers/ amp all seem to work fine.
I purchased the USB Audio Roadie. It seems to work to put out audio, but the problem I have now is that when it is plugged in it slows down my system. The video lags way behind the audio.
Anyone else have problems with audio output on thier T3?
Anyone know where I could get the on-board audio fixed?
Thanks!
Old 08-20-2007, 12:37 PM   #9
mtrydoc's Avatar
mtrydoc is an unknown quantity at this point
sorry to hear the problems you are haveing. Have a question if you do not mind about the rodie. With the sound come out of the rodie do you get all channels from the radio or only the fronts. I know with my T3 going through amp I only get sound coming out of front channels when I listen to radio.
MtryDoc
2006 Nissan Titan LE 4x4
Magetic Blue Crew Cab
4" Lift by PRG Productions
Infill T3 HU
Rainbow Sound Line SLC
ED Nine.1 Pushing 10v2 Sub
ED Nine.4 Pushing Components
"A Wife That Really Loves Me!!"
mtrydoc is offline   Reply With Quote
Old 08-21-2007, 09:26 PM   #10
I actually couldn't get the radio to work with the Roadie in StreetDeck. It seems the version of SD I was running no longer has the ability to let you choose your sound card output in options. (I don't know why this was removed).
So, the radio seemed to work, but didn't put out any sound at all. SD also ran horribly slow when the Roadie was connected.
Old 09-08-2007, 12:35 PM   #11
vitaminR is an unknown quantity at this point
I have a similar issue. My rear channel stopped working about a week ago. I have tried to test with Vinyl Deck but it won't run when I click on the app. Does someone have a copy of the installer? My installer CD was stolen months back.
vitaminR is offline   Reply With Quote
[CoupeE46] BMW E46 2001 330ci CarPC ... CoupeE46 Worklogs 54 10-02-2008 08:16 AM
Left arrow key has 'back' function associated with it S4Per StreetDeck Bug Reports 9 03-17-2007 02:06 AM
***Big 5 or 6 channel amps*** 3onDubs Car Audio 3 03-18-2006 12:02 AM
FS: Directed 650 5 Channel Amp- Brand New jeeplaw Classified Archive 21 08-31-2005 12:11 AM
FS: Kenwood KAC 744 4 Channel Amp $90 shipped jeeplaw Classified Archive 0 06-20-2005 10:51 PM
