Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Mp3Car Store Product Support Exchange > Infill T3
Old 07-09-2007, 07:12 PM   #1
ga_zander is an unknown quantity at this point
T3 Mute button not working
after my upgrade to wmp11 the mute button is not working
ga_zander is offline   Reply With Quote
Old 07-10-2007, 10:21 AM   #2
ScotLarsen is an unknown quantity at this point
Are you talking about the mute within SD? Or on the T3? What version of SD are you running?
Also, how did you manage to split your T3 components on your install? Did you find an extension for the Monitor/CPU cable?
Scot
ScotLarsen is offline   Reply With Quote
Old 07-10-2007, 04:01 PM   #3
i'm running 1098 and the mute button (on the monitor front) was working when i first upgraded to 1098 but after wmp11 it stopped.
it was a nightmare splitting that unit up into two, i could connect the rca wires, but i use and external amp for the car speakers. I had to rig the special connector with electrical tape and wire ties to get it to stay together during the install. I will ge adding a centre channel soon, so i will use one side of the t3s amp to drive it.
Old 07-11-2007, 11:34 AM   #4
Maybe you need to reinstall the DF&COM drivers for the Infill front panel?
So you found an extension cable for the CPU/Monitor connection? Based on the separation in your car, I have to imagine you used some sort of extension cable?
Scot
Old 07-11-2007, 05:02 PM   #5
no extension the units are about a foot apart in the back.
Old 07-12-2007, 03:32 PM   #6
Wow I wouldn't have guessed you could stretch it that far. That must have been a nightmare to install. heaven help you if you have to pull it out!
Scot
Old 07-12-2007, 08:19 PM   #7
i have to take it out to change the cmos battery, my time does not keep. While im in there i will upgrade the ram.....
Old 07-14-2007, 03:54 AM   #8
irdrive is an unknown quantity at this point
...and why not the hard drive while you're at it...
Infill T3 with Infill Station
2007 Hyundai Sonata
irdrive is offline   Reply With Quote
Old 07-14-2007, 10:49 PM   #9
I might Just do that......
Infill T3 GPS not working irdrive Infill T3 10 04-13-2007 02:34 AM
Messed up mute button? VPrime Road Runner 1 03-15-2007 02:27 AM
iGmod Beta 2 release PURDooM Other Cool Stuff 625 05-12-2006 03:52 PM
Feedback on bottom global NAV veetid Centrafuse 55 03-12-2006 10:57 PM
Hibernation enabled, can't hibernate with Power Button Tercel96 Software & Software Development 6 07-20-2005 03:05 PM
