The MP3car.com Store
Go Back   MP3Car.com > Mp3Car.com Store > MP3Car Products - store.mp3car.com > Infill T3
Thread Tools Display Modes
Old 05-10-2008, 05:06 AM   #1
My Photos: (0)
Unhappy Help required with Infill T3 - power up
Hi everyone,
I've just acquired a secondhand Infill T3 and am having trouble getting it to fire up on a Molex supply.
I have to 'fiddle', plugging and unplugging the 2 unit's power cables and the large black connector that links the units whilst pushing the PC unit's power button. Every once in a while I get lucky and it starts - I then plug in the screen and it opens to show the normal boot screen however the hard drive is not being found. I've tried swapping with a spare 40Gb HDD and still no luck.
Is this a problem with not enough power getting to the unit or something else?
I notice the fan on the back of the PC unit is running when the ignition wire is connected without the unit actually being on.
Also, I sometimes get continuous flashing LEDs on the PC unit?
The PSU is rated at 30A on the 12v rail and is 550W but a voltage tester shows 11.44volts.
Unfortunately I don't have any instructions apart from a wiring install I found on the 'net.
Any help would be very welcome!!
Thanks,
David
davcom1 is offline   Reply With Quote
Sponsored Links
Old 05-18-2008, 05:15 PM   #2
My Photos: (0)
Ok, have now got the T3 to power up... sometimes!
I've found 2 of the FFC cables (very thin ribbons) to be damaged.
One was an IDE connector - now have HDD but no optical drive.
The other is the connector cable from the PC unit to the front panel - this is the one causing most problems as it seems to have some control over the power up process.
Can I by these cables as spares from anywhere??
Please help!!
Old 05-26-2008, 04:10 AM   #3
My Photos: (0)
Fixed it!
Cannot believe I've managed to get it all up and running.
I sourced some 0.5mm pitch 50 pin FFC cables from www.digikey.com and they arrived in the UK in 5 days.
Bought 3 different lengths and had to modify the width (no of pin outs) for the front panel and motherboard to fixed front cable but was quite easy.
Now have a fully working T3 and am very pleased.
Old 05-28-2008, 01:08 PM   #4
My Photos: (0)
Now have sourced the cables and the machine works 100%.
Sorted!
Sponsored Links
vB code is On
Trackbacks are Off
Infill T3 Screen Opening nicehomeslice Infill T3 1 03-14-2008 10:04 AM
Infill T3 static noise (Fixed, Problem solved) irdrive Infill T3 29 07-05-2007 09:57 AM
infill t3 isamfarina Centrafuse 1 04-09-2007 09:46 AM
Infill T3 in the UK: Some questions discopanda Newbie 1 10-14-2006 06:50 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
