The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 06-25-2007, 03:22 PM   #1
My Photos: (0)
sp13000 usb header compatibility
I just want to know if this http://www.frontx.com/cpx108_2.html is compatible with my mobo. I'm planning to get 2 of these because It looks very easy to mount it on my dash.
zyr55 is offline   Reply With Quote
Sponsored Links
Old 06-25-2007, 04:13 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Yes.
The headers for USB ports are pretty much universal.
For future reference, you can compare the pin-out of the FrontX pieces to what is in your motherboard manul (or silkscreened on the board itself).
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-25-2007, 04:53 PM   #3
My Photos: (0)
Thanks for the quick reply, I'm ordering 2 of these now...
Old 06-27-2007, 03:19 AM   #4
DeltaFX's Avatar
Vehicle: 2002 Mux'd 206 peugeot
My Photos: (0)
Beside the pseudo universality of usb pin header, the page you link is pretty clear and cover most of the possible cases you may enconter. It's mostly a matter of reading your mobo manual, and figuring what is the situation.
And if the pinout is really different you always can rewire the plug :use a pin to lift gently the plastic tabs that hold the connectors in the plug, pul them out of the plastic part, replug where there suposed to be to suit your mobo pinout
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
HOWTO: Power a USB Hub for the G4 god_of_cpu Mp3Car Infill G4 - Double Din Car Computer 22 10-25-2007 08:02 AM
A couple questions about wiring up USB. gthing Power Supplies 9 09-06-2007 05:32 PM
Help: VIA EPIA MII10000 Onboard USB Header m1c4a37 General Hardware Discussion 6 02-13-2007 01:06 AM
SP13000 USB problem, won't recognize anything Diewlay Lowmo General Hardware Discussion 0 06-04-2006 12:16 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
