Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 06-25-2007, 04:22 PM   #1
zyr55 is an unknown quantity at this point
sp13000 usb header compatibility
I just want to know if this http://www.frontx.com/cpx108_2.html is compatible with my mobo. I'm planning to get 2 of these because It looks very easy to mount it on my dash.
zyr55 is offline   Reply With Quote
Old 06-25-2007, 05:13 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Yes.
The headers for USB ports are pretty much universal.
For future reference, you can compare the pin-out of the FrontX pieces to what is in your motherboard manul (or silkscreened on the board itself).
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-25-2007, 05:53 PM   #3
Thanks for the quick reply, I'm ordering 2 of these now...
Old 06-27-2007, 04:19 AM   #4
DeltaFX's Avatar
DeltaFX is on a distinguished road
Beside the pseudo universality of usb pin header, the page you link is pretty clear and cover most of the possible cases you may enconter. It's mostly a matter of reading your mobo manual, and figuring what is the situation.
And if the pinout is really different you always can rewire the plug :use a pin to lift gently the plastic tabs that hold the connectors in the plug, pul them out of the plastic part, replug where there suposed to be to suit your mobo pinout
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
HOWTO: Power a USB Hub for the G4 god_of_cpu Mp3Car Infill G4 - Double Din Car Computer 24 03-24-2009 01:17 PM
A couple questions about wiring up USB. gthing Power Supplies 9 09-06-2007 06:32 PM
Help: VIA EPIA MII10000 Onboard USB Header m1c4a37 General Hardware Discussion 6 02-13-2007 02:06 AM
SP13000 USB problem, won't recognize anything Diewlay Lowmo General Hardware Discussion 0 06-04-2006 01:16 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
