Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 11-28-2007, 12:21 AM   #1
calibration not saving
So every time I start up my carpc, it makes it calibrate. I shutdown the computer and it said saving settings. Well I turn on the pc again and it makes me calibrate it.
Basically every time I turn on the pc it makes me calibrate the touch screen. Anyone know how to get that fixed so I don't have to calibrate it every time?
jnthn205 is offline   Reply With Quote
Old 11-28-2007, 12:34 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
in your touchscreen options there are 3 options for how often to calibrate. check the box for only once.
Old 11-28-2007, 12:42 AM   #3
ohh ok. I'll try this tomorrow, if it doesn't work I'll come back.
Old 11-28-2007, 07:53 PM   #4
well i checked and tere was no box for only once.
I have a 7" lilliput touchscreen. And everytime windows loads, it re-calibrates the screen by making me hold down on blinking x until x stops blinking.
You would think the calibration would save, but it makes me re-calibrate it every time windows loads.
Old 11-28-2007, 10:29 PM   #5
2k1Toaster's Avatar
I know I have seen this option. Each driver is different. I reccommend the touchkit drivers.
Old 12-01-2007, 06:18 PM   #6
im pretty sure the touchkit drivers are what came with my screen.
This is just too weird, I don't know why it doesn't save when I shut down.
Old 12-07-2007, 05:06 PM   #7
Run msconifg and under the startup tab disable/uncheck the 4ptcal program and that should stop your system from running the program at startup. Do this after you have calibrated the screen correctly though. Hope that helps.
Nos4R2
Nos4R2 is offline   Reply With Quote
Old 12-07-2007, 06:14 PM   #8
im running windows 2000. There is no msconfig.
Old 12-07-2007, 08:57 PM   #9
R33vit's Avatar
You may need to remove and reinstall the drivers.
During the re-install there will be a option to turn this off. If you chose to calibrate at startup during the installing of the drivers then that is what happens at every boot up.
R33vit is offline   Reply With Quote
Old 12-07-2007, 09:11 PM   #10
Arrow's Avatar
In your registry, try to find the program in these locations:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run
If you don't find them there, try your "Startup" folder under your start menu.
Just delete the value if it's in there.
Arrow is offline   Reply With Quote
Old 12-17-2007, 03:33 PM   #11
i found out what to do. Under MSconfig I just unchecked the 4autocalibration.exe and it is fine now. By the way, I upgraded to XP to increase bootime.
How do i get 25 point calibration? Snortonnorton LCD/Display 1 08-29-2007 04:21 PM
Microphone recommendation for calibration? htsource General Hardware Discussion 1 05-22-2007 03:53 PM
Xenarc 700 TS calibration issue ergman LCD/Display 2 07-12-2006 12:55 PM
Endless calibration. Blanqui Input Devices 4 09-11-2004 12:38 PM
Lilliput 4-point and 25-point calibration? chris in nh LCD/Display 3 06-20-2004 01:16 AM
