The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 04-26-2008, 05:41 AM   #16
My Photos: (0)
i bought one in the end, the reception with the included antenna is a bit suspect. reception with an external aerial is fine though.
nrgizerbunny is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 03:34 PM   #17
My Photos: (0)
Is this inside a house or in a car or what you're referring too?
Do think it would be possible to modify a car antenna cable, and change the connector to a type that fits in the piranhas connector for external antenna? If so, it would be possible to have a permanent connection to an external antenna, trough the carradio-antenna.
popztarr is offline   Reply With Quote
Old 04-28-2008, 01:12 AM   #18
My Photos: (0)
the reception with an external car antenna is fine. no problems at all. I'd say it was as good as a headunit although the sound doesn't sound as good as FM, sounds a bit harsher but there is no static even on the move.
I bought a blaupunkt window aerial for the car and its really good, just plugs in using RF connectors (I they are sma but can't remember off the top of my head)
Old 05-02-2008, 05:13 AM   #19
xn02558's Avatar
Vehicle: 1987/BMW/M6
My Photos: (0)
RR Skin integration
Hi folks, this sounds very promising. Has anyone integrated the Terratec Cinergy Piranha in a RR Skin yet?
________________________________________
Researching to beef up my loved M6 with a CarPC
xn02558 is offline   Reply With Quote
Old 05-02-2008, 06:46 AM   #20
My Photos: (0)
this: TerraTec Cinergy Piranha (DTT, DAB, T-DMB, DVB-T)
is radio + tv?
is compatible in CF 1.47?
thanks
Caso85 is offline   Reply With Quote
Sponsored Links
Old 05-02-2008, 10:07 AM   #21
xn02558's Avatar
My Photos: (0)
is radio + tv?
Yes, its about the only device i found, able to receive DVB-T and DAB- Radio. Since most people are unhappy with their AM/FM USB- Sticks, might be the way to go. Did read that it is quite CPU intensive, might run smoothly only with 2Ghz CPU's. Would like to know if the experts here have integrated the dingy already to any Skin.
Cheers
Old 05-04-2008, 05:47 AM   #22
My Photos: (0)
mmm not sure if its cpu hungry or not, i'm runing an athlon dual core with 2gb of ram and not noticed anything. can't help on the skin front though. But this little usb stick is really good! reception is perfect even when going at 120kph
Sponsored Links
vB code is On
Trackbacks are Off
Has anyone (UK) got DAB radio or mabe even Digital Terrestrial TV in carpc? mutilator General Hardware Discussion 2 08-23-2004 01:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
