Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 12-19-2007, 01:24 PM   #1
SpinOut123 is an unknown quantity at this point
Problem w/ Touchscreen or USB Controller?
I have a Lilliput 7" touchscreen (9-pin connector not sure of the model but the PCB has "W9486SB" printed in the top left corner). It was working but now the touchscreen doesn't work. I used the drivers from egalax.com and it kind of works sometimes. When I touch the screen it will beep. But no matter where I press on the touchscreen to do the 9 point calibration it always comes out looking like the attached image. If I do the draw test, whenever I touch anywhere on the right side of the screen it will draw a line to the far left. But it does seem to register vertically, just not horizontally. Is this an issue with the drivers, touchscreen panel or touchscreen controller? And I have tryied this on other computers with the same results. It was working up until about 2 or 3 months and has been off (wasn't using the carpc) since then.
No other devices were plugged into USB ports.
I want to know if buying a new touchscreen from MP3CAR.COM will help or if I'm barking up the wrong tree. Plus, I have no clue where to buy a new controller if thats the problem so I don't want to waste money on a touchscreen if I am going to have the same problems.
By the way, the touchscreen always comes up in the device manager but it hardly ever works (even the beeps when just touching it).
Windows XP Pro
EPIA-M & P4 2.8 on an Intel 845 chipset.
Not sure if you need any other info.
Any help would be great.
Thanks.
SpinOut123 is offline   Reply With Quote
Old 12-28-2007, 08:44 PM   #2
sathish17110 is an unknown quantity at this point
I had the same issue. try the drivers from lilliput website. The link is below. These are the only drivers that worked for me, hopefully this should solve your problem.
http://www.lilliput.com.cn/eng/service.asp
sathish17110 is offline   Reply With Quote
Old 05-16-2008, 12:40 PM   #3
Leegsi is on a distinguished road
Shame you cant download them anymore
Leegsi is offline   Reply With Quote
Old 05-16-2008, 01:50 PM   #4
russoxley187 is an unknown quantity at this point
try the drivers from the Cartft website
they work.
russoxley187 is offline   Reply With Quote
Old 05-17-2008, 02:15 PM   #5
Gredd is on a distinguished road
This is most certainly not driver related. I have this problem on my LinITX 8" and I did this
touchscreen panel repair
You need to upgrade your Flash Player
and it really helped...for an hour or so, then the problem got back. I'm looking for a more permanent solution to this.
Gredd is offline   Reply With Quote
Old 05-23-2008, 11:28 AM   #6
Moneyfink's Avatar
Moneyfink is on a distinguished road
You can download all of the drivers lsited from the liliput page by going to the internet archive
http://web.archive.org/web/200611061...ng/service.asp
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
FAQ: Everything you need to know about your Xenarc frodobaggins LCD/Display 43 10-24-2009 06:44 PM
Connecting touchscreen USB via Bluetooth? wake Wireless Communications 6 04-13-2007 05:18 PM
FS: Lilliput parts (Touchscreen controller, LCD, Touchscreen overlay) Grayscale Classified Archive 20 07-23-2004 10:26 PM
FS: 8.4" LCD with USB touchscreen lzrdkng14 Classified Archive 2 05-28-2004 04:40 PM
3m usb touchscreen controler question? kalito Input Devices 6 02-23-2004 07:45 AM
