The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 01-08-2008, 12:31 AM   #1
nitropwd's Avatar
Vehicle: 96, Chevy Cavalier ; 2004 Acura TL
My Photos: (0)
Need Options for powered usb hub
I need some options on getting a powered usb and how it should be powered. I currently have a unpowered 1.1 in the front of my car and looking to upgrade.
Oh, by the way i already have a Carnetix POL to start. Thanks.
Motherboard: M10k
Power: M2-ATX
Storage: 200gb 3.5"
Optical: Slim Slot cdrw/dvd (USB Enclosure)
Audio: SB Audigy
GPS: BU-353 & iGuidance 4
OS: Win FLP (Fundamentals)
Software: Roadrunner (Lucid Skin)
nitropwd is offline   Reply With Quote
Sponsored Links
Old 01-08-2008, 06:22 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Check the power supply for the powered hub. You want one that takes 5vDC.
Then you can use the Carnetix POL or take 5v from a HDD molex connector to power the USB hub.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-08-2008, 04:05 PM   #3
nitropwd's Avatar
My Photos: (0)
Thanks DP, I appreciate the response but what i need is a couple of makes and model of what people are actually using in their installs so that i have something to go off of.
Motherboard: M10k
Power: M2-ATX
Storage: 200gb 3.5"
Audio: SB Audigy
Old 01-08-2008, 08:15 PM   #4
My Photos: (26)
You can't go into a computer store and look at power supplies of USB hubs?
Ummm. OK.
My Worklog
Old 01-11-2008, 12:26 AM   #5
nitropwd's Avatar
My Photos: (0)
Good point...my bad. Anyway i picked up a 7 port with a 5V @ 2.2A. i think should be ok. Please let me know if i'm missing something.
Motherboard: M10k
Power: M2-ATX
Storage: 200gb 3.5"
Audio: SB Audigy
Old 04-11-2008, 08:43 AM   #6
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
Looking for the same thing. Yesterday I went by the shop that is doing my install and while we got everything working, windows gave "there was a surge on the usb" blah blah, and basically the DVD drive I think just pulled too much from what the on board usb could provide.
I found an old powered usb hub, and the power adapter reads:
Input 100-240 - 0.3A MAX
Output: +5v 1.2A
So from what Darque has said, I need that top line to say: 5vDC ?
I'm obviously not well versed on any of this yet, but I was thinking, since the output of this hub is the +5v 1.2A (0.3A per 4 of the usb's), that I can simply cut the power wire, and connect it to a 4-pin molex connector off the PSU. Then I confused myself, because I thought the 4-pin molex connectors are 12v (which is what is powering my LCD)
Any direction is appreciated!
Phatsacks is offline   Reply With Quote
Old 04-11-2008, 09:15 AM   #7
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
Post Molex drive connector voltages
Output: +5v 1.2A
The Molex four pin connectors that are for powering disk drives have both 5V and 12V. The wiring is:
Red --> +5V
Yellow --> +12V
Black(X2) --> Gnd
You should also power your USB optical drive directly from the molex instead of letting it draw from the USB ports.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 04-11-2008, 09:18 AM   #8
Phatsacks's Avatar
My Photos: (0)
Thanks JimmyFitz, so was I correct then? (minus my lack of fully understanding the cables)
I can splice a 4pin, use the red+black, and connect it to the power cord of the usb hub I described, and it should work?
Edit:
You suggested powering the USB Optical directly from the molex. This may negate the need for me to even need this USB hub (although I'd still like a confirmation, just in case I need it down the road).
It's a laptop optical drive, usb powered. How can I power it directly from a molex connector, instead of it using the USB hub, without splicing open the usb cable?
Old 04-11-2008, 10:15 AM   #9
JimmyFitz's Avatar
My Photos: (0)
Edit:
Did the optical drive come with a wall wart for use at home? If so, see if that is 5V output. If it is, you can cut the cable from it and wire that to your molex 5V (or get another coaxial connector for the drive.)
~Jimmy
Old 04-11-2008, 10:52 AM   #10
Phatsacks's Avatar
My Photos: (0)
They came with an AC plug attached to another USB/PS2 cable. I threw those worthless things away. I mean, who would ever need alternate power? Hahahaha seriously, what a worthless cable...never to be needed haha oh :supersadface:
Well, back to the USB hub idea I guess. So, the hub I described will work when splicing into red+black? Looks like it to me, but I'm not as savy as you and others.
Sponsored Links
Old 04-11-2008, 12:13 PM   #11
JimmyFitz's Avatar
My Photos: (0)
The hub still won't put out enough current to run the drive over USB. You really need the power cable. See if you can get a coaxial plug from rat shack or somewhere that will mate to the drive and hook that to 5V. Without the second power source, the drive will possibly be recognized by the PC but most likely will fail when it tries to spin up for use.
~Jimmy
Old 04-11-2008, 01:08 PM   #12
Phatsacks's Avatar
My Photos: (0)
Will do, thanks for the help!
Old 04-18-2008, 06:25 PM   #13
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
im looking to do the same thing althought the hub will be up front in the dash where as the pc and power supply is in the boot where can i pickup 5v?
EaRNi is offline   Reply With Quote
Old 04-18-2008, 11:03 PM   #14
JimmyFitz's Avatar
My Photos: (0)
Red --> +5V
Yellow --> +12V
Black(X2) --> Gnd
~Jimmy
Old 04-19-2008, 07:31 AM   #15
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
so i need a long wire from the boot to the front, just to power the hub?
Sponsored Links
vB code is On
Trackbacks are Off
Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub HiJackZX1 General Hardware Discussion 4 01-07-2008 03:42 PM
WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc CavityCr33p Classified Archive 1 01-30-2006 05:57 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 11:44 AM
USB HUB problems???? chuckctv Input Devices 7 10-08-2004 11:38 AM
Powering an unpowered USB hub? Squiddy Input Devices 5 09-02-2004 04:37 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
