The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 01-10-2008, 03:21 PM   #1
Vehicle: 04 BA XR8
My Photos: (0)
USB Cuts out on resume and every few minutes...!?
Im using a USB touchscren overlay and is works fine. The problem is to do with the USB port itself (i think).
I know it has been talked about before and i have searched, but after resuming from hibernate the touchscreen does not work. Apparently XP cuts power to the device and it doesn't come back on. Devcon and a refresh possibly be used to fix this. However i found it confusing as.
Even if i fix this... the touchscreen stops working after about 4-5 minutes.
If i restart the touchkit software it works a treat.
So maybe someway of closing and opening the touchkit software every 3 mins will work?? i know its not the best solution.
Or a program that refreshes the USB devices on a set interval??
Any help would be great. Cheers.
p.s. i am using eturbo touch drivers
toymachine is offline   Reply With Quote
Sponsored Links
Old 01-10-2008, 08:04 PM   #2
Vehicle: 04 BA XR8
My Photos: (0)
Ive since learnt about batch files that i can use to close and re-open programs. coupled with task scheduler i can achieve that at any interval a please. Just tweaking so that it doesnt start up over the top of my FE.
Old 01-11-2008, 08:04 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
DEVCON
There's a down & dirty tutorial on here. Search for it.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-11-2008, 09:55 PM   #4
Vehicle: 04 BA XR8
My Photos: (0)
Yeah i read it... well skimmed it and it seemed to complicated so all i did was...
use a program called hibernate trigger to close the touchkit program on hibernate via batch file... then reopen it (via batch file) minimised so it reloads the touch panel info....
i also moved the usb cable for the screen from its own port to the usb hub i am running.... and so far it hasn't dropped out. so for now all is good
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
