Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 01-19-2008, 09:23 PM   #1
tigergibb's Avatar
Remote Control Computer Startup
I bought a cheap remote control with one button to start up the computer before I get in my truck. The problem is it only works if the IGN is on... but the IGN starts the computer anyways. I have the remote wired to press the "power" button on the M2-ATX. If the computer is on, I can press the button on the remote and itll shut it down. I can then press it again to start it back up as long as I don't take the key out. If I take the key out and try to turn it on, it won't work. Anyone have any ideas as to how I can fix this? I'd really like to get it working so my computer's ready for me when I get in. Thanks, Daniel.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 01-19-2008, 10:08 PM   #2
tigergibb's Avatar
Here's what the thing looks like:
Got it off of eBay very cheap
Old 01-19-2008, 10:13 PM   #3
redls1bird's Avatar
sounds like you connected it to a power source that is on the accessory power supply, look for a constant 12 volt supply to connect it to.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 01-19-2008, 10:23 PM   #4
tigergibb's Avatar
I connected it to the "Power Button" pins on my M2-ATX so it acts just like a regular computer power button. I think the problem is that the M2-ATX doesn't want to start without IGN supplied even if the power button is pressed.
One possibility would be to wire one wire to +12V (with a diode so current can't turn on all my other devices) as you mentioned and the other wire to the M2-ATX's IGN wire. In that case, though, I'd have to hold down the button for a few seconds to get the M2-ATX started up and then get in the car within 45 seconds before it turns the computer off.
Old 01-20-2008, 08:43 AM   #5
Hook that thing up to a relay and constant power, and parallel that into the PC power supply...
WuNgUn is offline   Reply With Quote
Old 01-20-2008, 11:24 AM   #6
tigergibb's Avatar
I guess I'd be looking at something like this:
http://www.the12volt.com/relays/page5.asp
"Latched On/Off Output Using a Single Momentary Pulse"
I've never worked with relays before so this should be interesting
Anyone have any ideas that doesn't use so many relays? I'm really looking for an easy install, but that usually never happens with CarPC's.
Old 01-20-2008, 01:10 PM   #7
You don't need a latching mechanism...
Just a pulse to trigger the on/off ATX switch, correct?
Old 01-20-2008, 02:17 PM   #8
tigergibb's Avatar
That's what it does right now, but for some reason it will only work if the "IGN" is on . Any ideas?
Old 01-20-2008, 04:33 PM   #9
I guess you need a relay on the main power going into the power supply...
Have it setup so the remote turns it on and/or the ign. turns it on...
I guess you'll have to make a latching setup with the relays. The only single latch relay I know of is from Allen-Bradley, and it isn't designed for auto use, but it is 12V...
You also might have to configure the M2 differently? I haven't got mine yet, so I can't be certain.
Old 01-20-2008, 06:03 PM   #10
tigergibb's Avatar
I didn't want to configure the M2 as a "standard PSU" because I like how it turns on/off with the car. I have it set for 5secs OFF 45ses HARDOFF. I'd like to at least press the remote and have 45 seconds to get in the truck and turn it on. I don't have a pic programmer to reprogram it, nor do I know how to use a pic programmer.
The only question I have about a latching relay is how would I have it unlatch automatically? I wouldn't want to get out of the truck and instead of the computer turning off automatically when the IGN signal goes away, it just stays on because the relay is still latched from when I pressed the button on the remote. Any ideas? -Daniel
Old 01-20-2008, 06:09 PM   #11
The way it latches, is from a momentary 'pulse' from the remote...it unlatches the exact same way...a pulse from the remote...
My AB latching relay unlatches with a reverse polarity input, which complicates things...
Old 01-20-2008, 06:44 PM   #12
Arrow's Avatar
You can use two relays and two diodes like this. When you push the remote button, it latches the relay on the right. When you start the ignition, the relay on the left disconnects power to the one on the right, releasing the latch.
Arrow is offline   Reply With Quote
Old 01-20-2008, 06:56 PM   #13
the m2 should be powering on when the switch is pushed no matter what state IGN is in. I have one and it powers on and off with the push button at all times. Perhaps your constant and IGN are reversed on your M2. Just my 2 cents
etsicc is offline   Reply With Quote
Old 01-20-2008, 06:58 PM   #14
Arrow's Avatar
My M2 will not power on unless the IGN is on. Maybe they changed something over time
Old 01-20-2008, 10:12 PM   #15
tigergibb's Avatar
I know my power and IGN aren't switched because I have a SPDT Center-Off switch to control when I turn the computer on/off. Maybe they programmed them differently?
Thank you for the diagram arrow. That's a lot more what I'm looking for. I've never worked with relays/diodes before so where do you suggest I purchase them from(cheaply)? What kind of relays/diodes do I need?
-Daniel
Remote Control Fusion Brain. alexgray104 Fusion Brain 9 09-06-2007 03:16 AM
CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU ProCos General Hardware Discussion 7 06-16-2006 03:27 AM
Turn your computer on by remote control PaulzY General Hardware Discussion 22 03-02-2005 02:06 PM
car remote control cooljavy General MP3Car Discussion 3 09-27-2003 01:00 AM
Great ir remote to control mp3car rcpirate General Hardware Discussion 5 10-16-2002 12:01 AM
