The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 02-08-2008, 10:33 AM   #1
My Photos: (0)
Toyota Steering Wheel Control Question
Dear all,
I have got a Toyota Yaris hatchback that comes with standard CD player, but no steering wheel audio controls.
Now I got given an OEM steering wheel controlled Bluetooth Handsfree for the new Yaris, but I know that it requires the steering wheel audio buttons to function properly.
Does anyone know the schematic of the Toyota steering wheel audio control buttons? And where they connects to?
There are 5 buttons, Mode/vol+/vol-/Up/Down. I am hoping to build a small panel with 5 push buttons and mount it somewhere on the dash (or hidden) and hook it up just like the standard steering wheel controls.
I have found the wiring connection:
http://www.castulucci.com/projects/carpc/o...tors/index.html
There is a 20 pin plug contains 3 wires that comes from the steering wheel control buttons:
Pin 6: GND (Ground from Steering wheel audio controls) - Neither Input nor Output - Connected
Pin 7: SW1 (Seek+/-, Vol+/- Inputs from Steering wheel audio controls) - Input - Connected
Pin 8: SW2 (Mode input from Steering wheel audio controls) - Input - Connected
Now the question is... can someone with the steering wheel control buttons on their car be so kind to measure the resistance of each button when they are pressed (and when they are not pressed, in case there is a particular resistance in the steady state)?
And if you know that the 5 control commands is not as simple as "difference in resistance", could you please tell me how to make this work?
Thanks in advance! And if I am successful in building a 5 button panel to simulate the buttons on the steering wheel controls, I will write up a very detailed DIY instructions!!!
205GTi is offline   Reply With Quote
Sponsored Links
Old 02-08-2008, 06:47 PM   #2
My Photos: (0)
This is the diagram I have in mind (pure guess), the values of the resistors is what I am after.
Please could someone help me out on this? Many Thanks!
Old 02-15-2008, 02:22 PM   #3
vitecd's CarPC Specs
vitecd's Avatar
Vehicle: '00/Honda/ferio
My Photos: (0)
hi
how are you planed divide key between car music and carPC?
simply interface can be attached to Joystik port, MIDI
http://www.e-lis.ru
vitecd is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VZ Monaro ('04-'05 Pontiac GTO?) Steering Wheel Control interface BradJ Input Devices 3 05-06-2008 08:25 AM
FAQ: Hacking Your Steering Wheel Buttons to Control Your PC Bugbyte The FAQ Emporium 73 03-09-2008 06:14 PM
Using steering wheel controls to control mini mac? brandondente MacCar 7 05-12-2005 09:50 AM
RF keyfob remotes for adhoc steering wheel controls? archimense Input Devices 27 12-23-2004 04:27 AM
Pioneer steering remote with IRman question magnetik General Hardware Discussion 4 12-08-2001 01:47 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
