The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 02-23-2008, 02:23 PM   #1
grahamrb's CarPC Specs
Vehicle: Toyota Echo 2003
My Photos: (0)
K90 replacement touch panel?
I recently purchased a second hand K90 in-dash motorized 7" touchscreen LCD.
I've found that a few minutes after calibrating the LCD the calibration goes out, the mouse is about 1 cm below the touch position.
Anyway, some searching around here told me that this means my touchscreen overlay is on it's way out. So what I need is a new touchscreen, I'm wondering if the lilliput replacement overlay from mp3car (http://store.mp3car.com/7_Touchscree..._p/mon-028.htm) will work for this screen? Are there ones off ebay that will work? Is the replacement process easy?
Thanks for any advice.
grahamrb is offline   Reply With Quote
Sponsored Links
Old 02-29-2008, 01:11 AM   #2
st1mpy's CarPC Specs
My Photos: (0)
I also have a K90 although it is new.
Sometimes when I go back to Centrafuse or Windows after hibernation, he only accepts the right side of the screen.
It seems that the Windows cursor is 4 cm to the right side.
Can this be with resolution?
Because normally it accepts 800x480 but I can only set it to 800x600.
Damned EPIA m10000
When I connect a USB mouse & perform the 4 point calibration he remembers again for a few days/ few hibernations.
For your information it is connected via this way.
PC ====Active USB cable =>>> Powered hub =>>>> Touchscreen
st1mpy is offline   Reply With Quote
Old 04-21-2008, 02:44 AM   #3
My Photos: (0)
When I put it in the first USB port from powered hub it stays, the rest of the USB ports the touchscreen gets out sync sometimes.
Sponsored Links
vB code is On
Trackbacks are Off
8.4 touch replacement dmcdlrn LCD/Display 1 04-02-2006 11:36 AM
Digital World Wide Touch Panel Kits (6397) CfdRescue910 LCD/Display 4 07-27-2005 11:14 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
