The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 03-05-2008, 01:11 AM   #1
My Photos: (0)
Which rear view camera, between these two?
Hello,
Can anyone comment on which of these two cameras may be the best in respect to specifications or any others equally appropriate. I would like to use one for a rear view camera and also possibly a front view cam. I will be accommodating these requirements via a direct Xenarc monitor connection and USB capture adapter.
I’m just interested in anyone’s view on these cameras in respect to their use or differences such as the Minimum Illumination, Built-in Lens, Lens Angle and other differences?
1)
Rectangular Bracket Mounted Camera
http://precisionvision.com.au/pdf/ProductSpecsV2.pdf
1 / 3” COLOR CCD SENSOR SPECIFICATIONS
With Audio and IR
Image Device: SHARP
TV System: PAL / NTSC
Effective Pixels: 512 x 582 pixels / 512 x 492 pixels
Sensing Area: 4.9mm x 3.7mm
Scanning System: 2:1Interlace
Sync. System: Internal
Resolution: 420TV lines
Horizontal Sync. Frequency: 15.625KHz / 15.734KHz
Vertical Sync. Frequency: 50Hz / 60Hz
Minimum Illumination: 0 Lux/F1.2 with IR
Microphone: Optional
Video Output: 1.0vp-p, 75Ohm
Gamma Consumption: 0.45
AGC: Auto
S/N Ratio: Better than 48dB
White Balance: Auto
Electronic Shutter: 1/60(NTSC) / 1/50(PAL) ~ 1/10,000 Seconds
BLC: Auto
Current Consumption: Max. 300mA
Power Supply: DC12V
Operating Temperature: -20°C~70°C , RH95% MAX
Storage Temperature: -40°C~80°C,RH95% MAX
Lens: f=3.6mm / F = 2.0
Lens Angle: 92°
2)
Yan Laboratory Electric Science & Technology (USA) LLC
CCD Color EXTRA Heavy Duty Commercial Grade Night Vision Infrared Wide View Angle Vehicle Rear View Backup Camera
Model Number: CW134086CI, CW134086CAI (audio model)
http://home.comcast.net/~yanlab/usa/...amera_086.html
System Specifications:
Image Sensor 1/3" SHARP CCD Sensor
Horizontal Resolution 420 TV Lines
Horizontal Sync Frequency 15,734 kHz
Vertical Sync Frequency 60 Hz
Effective Pixels 519(H) x 492(V)
Minimum Illumination 0 LUX (w/ LEDs on) / F:2.0
Sensing Area 4.9mm x 3.7mm
Number of IR LEDs 28
Video Out Signal 1.0 Vp-p 75 ohm
IR Distance Approx. 35 - 50 feet (10 - 15 meters)
AGC Auto
S/N Ratio Better than 48dB
Electronic Shutter 1/60 - 1/10,000 second
Weight Approx. 18.5 oz (525 g)
Sync System Internal
Built-in Lens f=2.8mm / F=2.0
Current Consumption Max 400mA
BLC Auto
Gamma Consumption 0.45
Power Supply DC 12V
White Balance Auto
TV System NTSC
Operating Temperature -4°F - 158°F (-20°C - 70°C) / RH 95% Max Storage Temperature -40°F - 176°F (-40°C - 80°C) / RH 95% Max
Cable Input/Output (2 Sockets) Yellow Socket - RCA Video Output,
Black (or Red) Socket - DC Power Input
Lens Angel Wide View Angel 120°
Regards,
DEM_968.
DEM_968 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Rear view camera MBUC1 - disable autodimming feature? (from mp3car.com) krnpimpsta General Hardware Discussion 5 02-24-2008 09:00 PM
What to use for rear view monitor? stonestatue Newbie 11 01-22-2007 10:59 PM
rear view camera problem.. hotponyshoes General Hardware Discussion 2 12-20-2006 08:23 PM
Have video camera for rear view - which program? nxt125 Software & Software Development 0 08-14-2002 11:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
