03-13-2008, 08:49 PM
#1
Vehicle: ///M3
RF or Bluetooth keyboard work in bios??
I will have enable usb keyboard set to on in bios but my question is will it be recognized it if it is a wireless keyboard (likely Bluetooth, possibly RF)?
Thanks.
EDIT: Or, even cooler would be if you could use T9 on a bluetooth phone to do your typing... That for sure wouldn't work in bios tho.
03-15-2008, 12:14 AM
#2
Vehicle: ///M3
bump
03-15-2008, 08:27 AM
#3
Vehicle: 2002 Thunderbird V8
RF but not BT
Thanks.
A Bluetooth keyboard will not work for bios setup because the drivers won't be running until sometime after windows starts up. An RF wireless that uses a USB receiver looks the same to the PC as a wired USB keyboard. Most newer PC's recognize these in the bios.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
03-15-2008, 09:52 AM
#4
Vehicle: 04 Camry
I agree. I have a gryation rf keyboard and remote. Keyboard works fine in bios, but the remote doesn't. Pretty much what I expect because the remote is handled via a driver that isn't loaded until windows is.
I also use a regular wireless keyboard (also rf) and it works well too.
Yeah google!
03-16-2008, 12:41 PM
#5
Vehicle: ///M3
Thanks guys. Thats kind of what I was thinking.. Only problem is you need line of sight with IR, right? or would it work through a glovebox door OR if I ran a usb cable out and put it under my armrest to plug the IR reciever into. (not direct line of sight, but in the open) Thanks again.
03-16-2008, 02:04 PM
#6
Use RF, not IR
IR is line of sight. I suggest you pick an RF (Radio Frequency) wireless USB keyboard. There are many to choose from which are not Bluetooth.
~Jimmy
03-16-2008, 03:12 PM
#7
Vehicle: ///M3
Yeah I'm dumb, I meant RF. Thats the direction I'll go since it's not line of sight. Thanks again.
| Thread Tools |
| Display Modes |
Linear Mode
