The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 04-24-2008, 07:09 PM   #1
Vehicle: 2003 Nissan 350z
My Photos: (0)
Looking for a webcam to use as back-up cam
I am looking for a decent priced USB camera ( IR and good viewing angle) pretty good quaility and hgopefully no lag as I cant go composite although id love to due to my lilluput not havin auto -siwtch
thanks
ukraini9mofo is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 01:23 PM   #2
My Photos: (0)
any1 any input?
Old 04-27-2008, 01:32 PM   #3
froalskiner's CarPC Specs
Vehicle: 06 G35C
My Photos: (0)
There are a few threads on this but nothing conclusive about which cam is the best. Some people go for the license plate attached spycam type cameras and a few others have tried USB based webcam versions.
Again, nothing really conclusive on any of them. A lot of people with Xenarc screens like the license plate cams since the Xenarcs automatically switch to the camera when power is applied. Normally they are connected to the reverse lights so when you back out of your driveway the cam turns on automatically.
Do a few searches on this and you'll see several examples of what people are currently using.
You do however get what you pay for so the $20/ebay webcams dont give you the picture quality of the $100 dedicated backup camera. The issue with these are ease of installation since they can require a modified housing or hole in your trunk.
Which ones are you looking at?
Planning: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Bench Testing: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Car Installation: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Overall Progress: 95% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓- ->
My Worklog
Wants Mr. T NAV Voices!!!!
froalskiner is offline   Reply With Quote
Old 04-27-2008, 09:12 PM   #4
My Photos: (0)
http://cgi.ebay.com/NEW-6-LED-Night-...QQcmdZViewItem
I know this is extrelemly cheap but maybe this will provide sufficient quality?
Old 04-28-2008, 12:07 AM   #5
CLUCK's CarPC Specs
My Photos: (0)
The Ebay item has finished, but looking at the vendor's store I see a camera boasting 54degree viewing angle. This is NOT good for a backup camera.
MP3car store has a 110degree camera, I would go for this as a minimum.
CLUCK is offline   Reply With Quote
Old 04-28-2008, 03:28 PM   #6
My Photos: (0)
well the angle is 60 so I am guessing it is not enough
any1 know of any usb night vision cameras with angle of 100+?
Old 04-30-2008, 11:08 AM   #7
blckwdw's CarPC Specs
blckwdw's Avatar
Vehicle: 1995/BMW/325iC
My Photos: (3)
have not seen any
"Toilets scare the crap of of me..."
blckwdw is offline   Reply With Quote
Old 05-08-2008, 11:12 PM   #8
My Photos: (0)
look around for internet / computer security cameras. Then generally able to record at very low light levels. Make sure it has good res and frame rate since that is a general weakness in security cams
nblracer is offline   Reply With Quote
Old 05-12-2008, 06:45 AM   #9
MitchellO's CarPC Specs
MitchellO's Avatar
Vehicle: 2000 Mitsubishi Verada
My Photos: (0)
The problem I have found with my cheapass USB camera is that it is too bright outside for it to work. The image is completely white.
What can you expect for $12 delivered...
Mitsubishi Verada KH
Car PC Installed and working great!
MitchellO is offline   Reply With Quote
Old 05-12-2008, 07:19 AM   #10
lukec's CarPC Specs
My Photos: (0)
I've been skulking around to find a good reverse camera as well and it really doesn't look like anything usb is going to work very well especially in low-light conditions.
CCD, component video with built-in IR illuminators are really probably all that will get a good quality video resolution in all weather conditions.
How are you planning on switching to the reverse camera's view within your front end? Seemlessly switching from the front end's current screen (whatever it may be) to the reverse camera when you actually put your car in reverse (like OEM equipment does) seems like it might be quite a task.
lukec is offline   Reply With Quote
Sponsored Links
Old 05-12-2008, 06:44 PM   #11
CLUCK's CarPC Specs
My Photos: (0)
A trigger from the reverse light wire to a relay to provide power to the camera is quite easy. Xenarc screens have the ability to auto switch to AV when a signal is detected.
Not sure if Lilliput screens have the same or not.
When I get around to it I will be using a video capture card to the PC, so software will drive the display - with record abilities too. I think I'll use something like fusion brain to send a hot key to switch the display when reverse is selected.
Old 05-13-2008, 06:49 AM   #12
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (162)
Certain Lilliputs do, and some dont, the ones that dont can be mod'ed to do it.... CAM wise I went with a 60 angle, which isnt great for most setups, but when you have 3 cams its ok......
PLANNING [IIIIIIIIIIIII] DONE
ITEMS [IIIIIIIIIIIII] DONE
INSTALL [IIIIIIII---]
BUDGET [IIIIIIIIIIIIIIII]IIIIIIIIIIIIII
HiJackZX1 is offline   Reply With Quote
Old 05-14-2008, 06:59 PM   #13
lukec's CarPC Specs
My Photos: (0)
Thanks Cluck! I'm going to jot that down to search out some solutions for that reverse light relay.
Back to searching...
Sponsored Links
vB code is On
Trackbacks are Off
Cam Plugin hari-bhari Centrafuse 6 02-04-2007 05:34 AM
Webcam For A Backup Cam? we87 General MP3Car Discussion 5 01-30-2007 12:23 AM
Any special requirements for backup cam? showson1 StreetDeck 1 10-27-2006 06:32 PM
CAM plug-in suggestion SOS CF Plugins 2 09-08-2006 05:04 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
