The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 05-06-2008, 01:31 PM   #1
Vehicle: 2001 Audi TT Quattro Coupe
My Photos: (0)
My Griffin Powermate install
I had no idea where I was going to put my Griffin Powermate in my Audi TT when I received it. It was larger than any other button/knob in my car and stood out (which I didn't want) due to its huge silver base.
After a few days of work (not knowing what I was doing) I got it mounted. So, where is it?
TTeuer is offline   Reply With Quote
Sponsored Links
Old 05-06-2008, 01:56 PM   #2
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
The hazzard button? Very nicely done! Good steath install no matter where it is.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 05-06-2008, 02:04 PM   #3
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
Now that is sweet!
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 05-06-2008, 02:07 PM   #4
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (31)
LOL! nice.
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 05-06-2008, 02:31 PM   #5
quantum's Avatar
My Photos: (4)
Very cool indeed!
How about a quick write up on what you did, how it works, what modifications were necessary, etc? Orther pics perhaps?
I for one would love to emulate ya'
On the plus side, my carPC is NOW complete and running great!!!
Summer '07 : Caddy-puter 2.0 with smaller, better and way more cooler stuff!
quantum is offline   Reply With Quote
Old 05-06-2008, 03:37 PM   #6
My Photos: (0)
It's the left most, blank, black button. My car didn't come equipped with heated seats so I had those two black buttons available. It took a lot of trial and error as acutally mounting the button in there was NOT easy.
1) I had to cut the original black spacer a couple of times. First I cut off just the front of it enough so the cuts would not be exposed once mounted like it is.
2) I used the silicon/plastic piece that came inside of the Griffin Powermate knob
3) I still had to use the back of the original black spacer because that is part of what locks that whole row of buttons in place. I could only cut it back to a certain point without ruining the integrity of it so I had to then cut off part of the Powermates metal "D" shaft so it was shorter.
4) I then had to grind away part of the silicon/base that I super glued to the back of the black knob because I needed the shaft to sit further into the knob. Without doing that, the black knob stuck out about 1/8 - 1/4" too far (I never actually measured anything)
5) I then superglued the back of the PCB to the black base that I mentioned in #3 and then pressed the original aluminum ring from my car over the knob and the PCB to create a sandwich (it was a perfect fit between the ring, powermate PCB, and the black base behind it).
It's hard to describe if you've never seen the spacer I'm talking about. Not many people with TTs even have since most of them came with heated seats - in which case this wouldn't have worked since those buttons are completely different internally.
Here are some pictures: http://www.brandonauch.com/TTEUER/Gr...Powermate.html
They aren't very good but they may help explain what I mean... The only tools I used were a Dremel and ... Super Glue if you would call that one.
Old 05-06-2008, 04:08 PM   #7
quantum's Avatar
My Photos: (4)
Very good explination, love the pics
You still have the ability to spin the little knob and/or push it? I'm guessing you would spin it with your fingertip on the edge?
TY!
Old 05-06-2008, 06:20 PM   #8
My Photos: (0)
Yep, it spins easily and it pushes in just like before. It's easy to spin, the dimples on the side of the plastic knob make it easy to just spin it with your finger tip.
Sponsored Links
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
millsy
vB code is On
Trackbacks are Off
AMP and Griffin Powermate thanassius AMP 8 04-17-2008 07:27 AM
FS/FT: Griffin Powermate Silver xdjxklusivex Classified Archive 6 04-13-2006 12:23 AM
WTB: Griffin Powermate acura cl Classified Archive 0 08-21-2005 11:50 PM
The Griffin Powermate tejohnson General Hardware Discussion 16 02-21-2003 04:48 AM
XMMS "General Plugin" for Griffin Powermate Control tejohnson General Hardware Discussion 2 10-27-2002 01:26 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
