Not too sure exactly what your question is, but I tend to go through time-honored, but sometimes tedious troubleshooting:
>Take a monitor from your house and connect it to your carpc with a short known-good cable. If you can see your carpc video, then carpc video output is good.
>Test the same monitor using the longer cable from your carpc (trunk?) to your test monitor. That tests your regularly used carpc cable...
>I use a Lilli 629, and remembered that I had to load cdrom touchapp to use touchscreen with my carpc. It worked first time, but occasionally my screen will flash briefly, and a message like "touch app stopped woking, but recovered..." will appear.
Anyway, I just suggest getting back to basics of maybe testing your carpc on workbench where you can control most everything in order to do process of elimination troubleshooting.
Best of luck and blessings.
Happy CarPC'ing!
