Lilliput 629 (transflective) touchscreen problem
I've had this since March, this is the 2008 model. It worked great for about the first 2 weeks, then I noticed I've had to calibrate it about once a week.. then it later it came down to once every 3 days.
Fast forward to about 3 weeks ago. I can no longer calibrate it to where it works. I try the 4 point calibration, clear and calibrate, 9 point, 25 point. Any of them, after i finish, the mouse just jumps to a corner and sits there no matter where I touch it.
Now as of a few days ago, the touchscreen no longer recognizes any touches. If you try the 4 point calibration, it doesn't even detect being touched anymore.
I'm pretty sure the driver is good as it worked great initially - I'm using the egalax one and I've updated that as well to see if that would fix it. To see if it was maybe my system I pulled the screen out of my car and tried it with another computer and it detects the touchscreen when I plug it in the USB and I give it the driver I've used in the car, but again when you try calibrating, no detection of touch.
Any ideas?
