G4 Screen won't calibrate after Windows Update
I took out my Infill G4 and decided it was time to do some XP updates (like SP3,etc) as my StreetDeck hasn't worked in a few months now, so I thought this might help. As part of the updates, there was a new touchscreen driver for Jastec RU Touch Screen Controller (02/18/08 v6.0.6000.10218).
Now my cursor is misaligned. When I run the calibration tool, it does the first "dot", then the second "dot" and as soon as I let go after they've both turned blue (as per the directions), I get a dialog pop-up that says:
Calibration
Your Panel Connection is not properly adjusted
[OK]
Clicking okay just causes it to start calibration over.
I've tried the 5-point and 25-point. With the latter, it will go through the first four points and then gives that message.
So where do I get the old driver? And why doesn't this new one work!?
I look in Control Panel > Add/Remove and I don't see this driver even with "show updates" checked. But if I go to Windows Update (Online) and review my history, I see it there, but there's no option to uninstall it.
