The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 07-23-2003, 03:47 AM   #16
Vehicle: 91 Toyota Celica
My Photos: (0)
don't these things work like when you move your finger across the red thing it moves the mouse in that direction? That could be handy... wonder if it could be put into a shifter... hmmmm http://www.meci.com/default.asp?part...n=&mode=Search
Cordell
Cordell is offline   Reply With Quote
Sponsored Links
Old 07-25-2003, 01:31 AM   #17
Vehicle: 2002 Civic EX
My Photos: (0)
Exclamation Voice Control
I don't know if anyone will even get this far in reading but I have a little info on the state of Voice Control. I was using it to control my own program (Flash 5 interface with Microsoft Voice SDK 4.0 (and briefly 5.0)). My experience was that with the old 4.0 SDK, the recognition was fairly good with only a few failed recognitions and a few false ones. This was pretty consistant even with the A/C on and the windows open at low speeds (up to 45 mph ish). Though I had to speak loudly to be recognized over the other noise (not quite yelling, but loud speaking like an actor would in a theatre) .However this luck with voice control only lasted so long and for seemingly no reason (though i'm sure there was one somewhere ;-)) it stoped working that well. I have yet to be able to fix the problem and am currently rewriteing my interface to work with a On1 Remote (do a search they are cool!). As a last bit of info, I tried Microsoft Voice SDK 5.0 briefly. It was had to get started with and thats why I quit, but it is SIGNIFICANTLY more powerful and has better recognition as well as being more suited to control application with lone statements ("Computer, Turn on, Mp3 Player, Play Track, By, Nelly"). If you have the time and are working on your own program I do recommend you go to Microsoft's webpage and download the SDK to atleast check it out. (included is a help file that will explain EVERY detail as well as pretty much teaching you how to program).
Hope this info helps someone :-)
Rick...
Laptopras is offline   Reply With Quote
Old 08-09-2003, 07:28 PM   #18
Registered User
gork's Avatar
Vehicle: BMW E46 M3
My Photos: (1)
Integrating a pointing stick or trackball into the shift knob would be a good idea. The pointing stick would probably be best/easiest. The OEM pointing stick linked to in a post above could probably be modified for this purpose.
The best approach, IMO is to put an RF keyboard that has an integrated pointing stick under your seat and also have a touchscreen. Then, if you want, integrate some custom dash buttons with one of the various interfaces there are. Here, I have seen links to various schematics for serial or parallel interfaces, but the method I think would be best is to get a controller made for arcade-pc's.. They hook to any kind of control you want and then emulate keyboard/mouse/joystick via USB or other appropriate ports. They are a little bit more expensive, but they will make integrating random buttons and other controls easier.
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 08-09-2003, 07:34 PM   #19
Registered User
gork's Avatar
Vehicle: BMW E46 M3
My Photos: (1)
BTW Re: the i-drive controller.. It is kind of like a jog dial that you can press down. It's a piece of !$)!@*# to use and it really sucks. IMO if you want that kind of controller in your car go for the griffin powermate. It's cooler and smoother. It doesnt have jogging though so it probably would rotate while you drive around.. They ought to make one with jog.
Anyway, the i-drive.. If you get ahold of one, you can integrate it pretty easily. It breaks out into basically 3 buttons exatly like a mouse wheel - jogged left, jogged right, pushed. Any of the button interfaces should work with it. It also has a connection for an internal light.
MY CAR IS FOR SALE!
Old 10-01-2003, 10:15 AM   #20
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
I have tried using my Laptop touchpad in the vehicle...too sensitive...while driving that is...
I like big buttons...like what the auto makers are now including with their onboard navigation systems.
(I also like big butts...but that is a different story)
current projects
DodgeCummins is offline   Reply With Quote
Sponsored Links
Old 10-10-2003, 10:42 AM   #21
smobot's Avatar
Vehicle: '98 Honda Accord EX
My Photos: (0)
Here's a tutorial on building a rotary encoder interface. You can get encoders with detents fairly cheaply at newark. Using a PIC, you could easily make a serial interface for this thing & write a quick and dirty keyboard input simulator to drive UI.
smobot is offline   Reply With Quote
Old 10-19-2003, 09:04 PM   #22
lawrence's Avatar
Vehicle: 99 caravan 04 G35s
My Photos: (0)
The 2nd coolest way to control a carputer seems to me to be a Phillips pronto and an ir remote. Pronto has an easy programmable interface / display. Ability to program 256 macros. All cool and looks good too!
Touch is the way to go
this link will take you to the new pronto's but you can check for older and cheeper ones on ebay
http://www.consumer.philips.com/glob...TE_CONTROLS_SU
lawrence is offline   Reply With Quote
Old 10-21-2003, 02:12 AM   #23
Vehicle: 92 Nissan Maxima GXE
My Photos: (0)
Works for me
I've used the X10 mouse remote in combination with girder and love it. I like the remote because I can control stuff without having to look at the screen, I can keep my eye's on the road. I also like the remote because the buttons are big soft and don't feel cheasy.
One complaint I have about the remote is it is a tad big for my liking.
If you can figure out how to use Girder with this thing (which takes a little bit of reading) then this can be a very powerful combination.
adamis is offline   Reply With Quote
Old 11-18-2003, 04:22 AM   #24
Vehicle: 84 Volvo 240
My Photos: (0)
Happy Hacker
Dont forget about the happy hacker. It is a small usb keyboard with a built in hub. It is a bit pricy ($60), but it feels solid, and works well. My old roommate has one in his car. He actually attached it above his glove box.
http://thomashargrove.com/car/images/overview-large.jpg
http://shop.store.yahoo.com/pfuca-store/
ME-6000, Lilliput 7" vga + touch, generic GPS, RedHat 9, custom mapping software.
ciagon is offline   Reply With Quote
Old 11-18-2003, 10:11 AM   #25
Seraph's Avatar
Vehicle: Subaru SVX 1992 / Subaru SVX 1994 / Mitsubishi Galant 1999 / VW Passat 1998
My Photos: (0)
You guys are missing a couple of stuff.
Check out microcenter(www.microcenter.com) for small keyboard and such. I also use keyspan Digital Media Remote as well as USBIR I got on ebay for 9 bucks. They are both amazing
As for voice software, use voiceflux(www.voiceflux.net)
- Lwin M. Maung
If it's stuck, force it. If it breaks it needed replacing anyway
Seraph is offline   Reply With Quote
Old 11-24-2003, 09:32 AM   #26
My Photos: (0)
real small keyboard
Has someone seen these allready??
http://keyboardspecials.com/oem.htm
rjbouw is offline   Reply With Quote
Old 11-29-2003, 11:10 AM   #27
XpAlEnDoCioUs's Avatar
Vehicle: 1970 VW Bugtle
My Photos: (0)
Rotary Encoder
What about a rotary encoder for volume and another tuning/scaning?
XpAlEnDoCioUs is offline   Reply With Quote
Old 01-06-2004, 09:30 AM   #28
Vehicle: 01 Dodge Ram QC 4x4
My Photos: (0)
Logitech also has the new Bluetooth diNovo keyboard system. The keyboard and numpad are spearate, and the numpad has an LCD, along with extra controls designed to operate media software. The whole setup is pricy, but I may take a look at it. It seems like it might work well in myssytem, since I am already using a keypad. Making it wireless and having the LCD (if it works with Winamp) would certainly be a big bonus.
KG6OQD
www.americansandassociation.org
AVGeek is offline   Reply With Quote
Old 01-13-2004, 11:25 AM   #29
Vehicle: Chevrolet Suburban 1995
My Photos: (0)
I use a PPC (currently an Ipaq 5450) connected to my carputer with WLAN (PCI card in the carputer, built in to the Ipaq) and NetRemote. With Media Center 9 (from J.River - I wouldn't touch Micro$oft's Meda Center PCs with a ten foot joystick!) I have full control over all aspects, from equlizer and volume to the full media library. I can find any song in about 15 seconds...in a close to 40 000 tracks MP3 library.
Tor - The MediaSUV
Mastiff is offline   Reply With Quote
Old 02-02-2004, 05:41 AM   #30
My Photos: (0)
Now that sounds cool!
Ormo is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
