The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 12-14-2005, 02:43 AM   #76
My Photos: (0)
Hey I'm thinking about using a joystick as a mouse and integrating it into the center console somehow so just the stick is protruding from the console along with surface mounted buttons. The joystick in question is the Saitek Cyborg 3D(picture attached) and the car is an 1989 Jeep Cherokee LTD.
Would this be a possible route or would I be better off going with a wireless mouse/trackball?
MarX is offline   Reply With Quote
Sponsored Links
Old 12-28-2005, 06:14 PM   #77
My Photos: (0)
I have found this on newegg not to bad.
http://www.newegg.com/Product/Produc...82E16817114134
Mic4 is offline   Reply With Quote
Old 12-28-2005, 06:23 PM   #78
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
2thread resurrection :P
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 12-28-2005, 06:29 PM   #79
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
I thought about the cyborg, too, for a minute. I think I had an issue the wiring and signal muxing so I went with the Logitech. It was an almost perfect fit over my gear shifter in my Eldorado. I use the 8-way hat for mouse movement and between the 6 buttons on the joystick and four more external I can contrl virtually anything on the computer. My son and I like it so much I've done comparable mods to his mustang convertable, too.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 12-28-2005, 11:45 PM   #80
My Photos: (0)
Quote: Originally Posted by ptk
just bought 1. fantastic except for no support for F11 and F12
How has it been since you have gotten a few more days to play with it? I ended up finding this post after I ordered one yesterday and was wondering if it does pretty much everything you need it to do or if there are some other shortcomings besides the F keys thing you said.
Fububutsy is offline   Reply With Quote
Sponsored Links
Old 12-29-2005, 05:15 PM   #81
ptk
ptk's CarPC Specs
Vehicle: 2006/VW/GTi
My Photos: (0)
hi
apart from the no F keys issue, it's fantastic. it pairs up within 5 sec upon power up. very nice backlight (orange). batt life slightly limited (1 week i think). oh, one more, it doesn't do combination key (ctlr-alt)
am going to see if i can mount it nicely on my steering wheel :P
CarPC Ver 3 near completion.
ptk is offline   Reply With Quote
Old 12-30-2005, 12:18 AM   #82
My Photos: (0)
hi
good to know I didn't waste 60 bucks, although it was kinda steep for a keyboard. But what are you gonna do?
Old 12-31-2005, 01:33 PM   #83
Mobtown's Avatar
Vehicle: 1996 Cherokee Classic
My Photos: (0)
I love the joystick as shifter idea and have looked through almost all of your past posts looking for more information on the setup...any chance you give some more detail? I am especially interested in how you mounted the stick.
Mobtown is offline   Reply With Quote
Old 12-31-2005, 04:13 PM   #84
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Not to try and create a work log or anything, but the short answer is I guess I got lucky. All three of my cars: 91 mustang vert, 95 Eldorado, 95 MB 320SL had sticks in the center console. Each has a different angle and handle, but basically if you can figure out how to remove the handle (mustang had 1 screw underneath, Eldo had to cut leather off to find allen screw, Benz I don't remember it was so long ago) and you carefully remove the base and preserve maximum shaft length from the joystick, the shifter shaft and joystick handle mate up fairly well.
The joystick handle will allow you some leeway in enlarging it to fit the shaft and if its opening is too big, you can always create another shaft that fits inside the joystick and outside the shifter shaft (try the joystick's own shaft first).
To regain shifter functionality, I went with the simplest methodology - I created a seat inside the joystick for the inner push rod from the shifter. this seat must be located such that the joystick can slide down the shaft 1/4 - 1/2 inches. (With the logitech, I preserved as much of the joystick shaft as possible rerouted the wires out the front bottom of the handle, used a drill press to open up the joystick shaft and it matched up beautifully). Grasping the joystick with my hand resting on the base of the handle, I move my whole hand down toward the shaft till it stops, then I can shift into whatever gear, and removing the pressure from my hand, the joystick pops back up and the shifter locks into gear.
With some cars the spring action of the pushrod is enough to return the joystick back up to the locked (in gear) position, if not an external spring will be required. Keeping as much of the joystick shaft intact was beneficial in the Eldorado cause once I got it to fit over the shaft, I cut a 1 inch line 1/8 inch wide in the joystick shaft, tapped a screw in the least visible location on the shifter shaft and put the screw through the line(this keeps the joystick from twisting round and around or coming off and allows me to use the handle twist action as volume control).
Then I just routed the wires along the shaft, through the shifter, and connected the joystick brains to the handle (i.e., the bulk of the joystick electronics resides inside the shifter) routed the usb cable to the computer and programmed Joy2Mouse.
My hat is my mouse control (8-way HAT is a must), trigger is left mouse, thumbswitch on left is right mouse. My software (Joy2Mouse) automatically switches profiles depending on whats in focus on the screen. So I have profiles setup for most of the software I use often. Fore example, in RoadRunner the two leftmost buttons on top control GPS/Exit, video/music, and scroll up/down, two righttop buttons are play/pause, prev/next, and phone/radio select. My FreeDrive and Map Monkey profiles inlude map zoom, rotation, routing, etc. Explorer and FireFox have scroll, pan, refresh, favorites, etc. Other buttons will be molded into shifter console.
Hope that helps.
Old 12-31-2005, 04:24 PM   #85
Mobtown's Avatar
My Photos: (0)
It does, thank you very much.
I have a slight bend in my shifter that might create some issues, but now I have a good visual to work from. Thanks again.
Hope that helps.
Old 05-16-2006, 04:51 AM   #86
My Photos: (0)
I hate you guys...
I love the idea of the joystick as a shifter.
But here in Aus, they're on the other side >.<
No fair..
It's almost enough to make me want to import an LHD...
Almost.
EDIT: Come to think of it, I wouldn't be too fond of the joystick shifter option on a triptronic transmission.
Un_discovered is offline   Reply With Quote
Old 05-16-2006, 05:00 AM   #87
My Photos: (0)
Also, thought this might be of interest to people looking for inputs (let's face it, we all are).
http://www.makezine.com/blog/archive...ake_a_w_1.html
It could also be adapted to use on an actual screen instread of a PDA.
In fact, some very interesting modifications could come from it.
Definately worth a look.
Old 08-14-2006, 11:40 PM   #88
tjsharktank's Avatar
Vehicle: 2004 Mazda3 & 2004 Nissan Titan
My Photos: (0)
Quote: Originally Posted by hd54321 View Post
As you requested maaaasta.....
Modded NES Powerglove
Enjoy!
WOW... that thing is, um, freaky.
Sara - I'm a geek from the word go!
2004 Nissan Titan
2004 Mazda3- Plans: Mac Mini, LCD, etc.
Previous Cars: 1999 Camaro- Alpine HU, Polk Comps, 2 Alpine 12" subs, custom encl
DON'T BUY FROM SETITE - HE'S DIRTY!
tjsharktank is offline   Reply With Quote
Old 12-20-2006, 11:56 AM   #89
My Photos: (0)
Hey guys, new to the board, but very interested with everything on it.
I have Motorola Q Smartphone which can Bluetooth link to the pc as a remote, it's really neat. Obviously you have to have your phone with you when u want to use it. It fully functions as a mouse, and I haven't done it yet, but I *think* you can use it as a keyboard also.
Nismo2006 is offline   Reply With Quote
Old 12-20-2006, 05:39 PM   #90
My Photos: (0)
Anyone considered / tried one of these?
http://www.thinkgeek.com/computing/input/8193/
AndyLcgy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
