Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 01-26-2003, 11:00 PM   #1
C4M
C4M's Avatar
NetRemote
Those crazy kids over at AVSForums have found someone that is setting up Pocket PC's as wireless control devices for their Home Theatre PC's: http://www.netremote.org/shots.html
Totally sweet.
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 01-26-2003, 11:56 PM   #2
CA 3000GT's Avatar
very cool, I think pda's and pc remotes may make computers in the car a little easier to use. I found a place that makes software to allow a palm to control a pc... so, I can buy a cheap thumboard keypad for the palm, and use it to type into the pc! the perfect space saver! if, if only the connection was fast enough to view normal video over, I would get one of those color palms, and forget about getting a screen for the car computer entirely!
1995 SL stock
Working On: GMAT
Given Up On: Custom motorized lcd
CA 3000GT is offline   Reply With Quote
Old 01-27-2003, 12:46 AM   #3
Registered User
not a practical application for a carputer. Requires a lan connection. Plus that prog seems to run only on pocketPC type pda.
Alphared is offline   Reply With Quote
Old 01-27-2003, 02:49 PM   #4
There are a lot of apps out there for the Palm also. I have tried Busker, PalmAMP and Jukebox at this point. Jukebox has the best interface from my testing. PalmAMP is the only one I can get to work on my Visor Edge though but it has good playlist editing.
Now if I could just bring my self to shell out the $85 to send my Palm Vx off to the Netherlands to be fixed....
Comp. Specs:Shuttle SS40G, Athlon XP 1700+, 256MB DDR, 40GB HD, Belkin Desktop 802.11b card (good range), SB 128 sound (onboard is a bit noisy), DVD ROM
Toshiba 100CS laptop, P75 40mb ram, 550MB HD, Megahertz LAN/modem PC card, modified to run off 12VDC
Other stuff:Generic USB hub & USB to serial adapters, BS2SX power control system w/battery buffer, Jazz 300W Inverter, FM Modulator, Palm Vx, & GPS
Status: 80% complete (Almost done with the controle boxes)
Sir_Pyro is offline   Reply With Quote
