Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 02-15-2003, 01:46 PM   #1
irman question
so how does this irman work..i jus boy the irman and it easily hooks up and then it works..or do i need sumtin else or is the irman all i need..do i need to buy a remote to hook up to it or what? im confused
matt
thaladyzman is offline   Reply With Quote
Old 02-15-2003, 02:37 PM   #2
Raw Wave
Rob Withey's Avatar
This is the evation page about it, it contains some useful information.
http://www.evation.com/irman/index.html
Basically the irman turns the IR signals of any remote into a sequence of numbers that the PC reads through the serial port. This is used to control programs. You can use pretty much any remote (you train the device). The irman doesn't come with a remote, you'll need to get one separately.
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
