Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 04-09-2009, 02:56 PM   #1
stevo7790 is an unknown quantity at this point
Broken Touchscreen
Hi Guys,
New member here I hope to be around in the various other topics and stuff in the future, for now though I have a more pressing matter.
I bought a 7" touchscreen, I have no idea of the make just that the LCD works.
However the touchscreen is cracked, looks like it could have taken a knock in the post.
Doing a bit of reasearch, I can see that the t'screen operates indepentantly of the LCD through software.
The screen is powered by USB and the ribbon for the comms inserts directly into the control board.
When the software is installed on my car pc I can see the touchscreen but can't calibrate it, which is quite obvious because if the crack I guess.
My question is can I use any Touchscreen?, the screen I have is 4 wire, so that is the screen I would prefer to have.
Sorry if this appears like advertising but Touchkit.com have a 7" screen that looks like the one I'm after, they sent me a ton of pictures and other info, but the connector from the ribbon cable to the control card uses a 4 pin connector to connect one to the other, again does this pose a problem? is it just a case that if the screen is the same size and same wire ( 4 wire for example) then it will work ok?
Hope you can help me, or put me on the right track, by the way I bought the LCD and touchscreen for next to nothing so I'd rather buy the screen than send the whole lot back.
Thanks alot people.
Steve
stevo7790 is offline   Reply With Quote
Old 04-09-2009, 06:15 PM   #2
upspace is on a distinguished road
those are cheap pieces of tai***n crap. i already had two of those (lilliputs) with broken touchscreen interface after 1 year usage.
not made for car usage (vibrations, temperature etc.)
upspace is offline   Reply With Quote
Old 04-09-2009, 06:33 PM   #3
kibble's Avatar
kibble will become famous soon enough
I bought a 7" touch screen kit (that I have yet to use) from a site called deal extreme, looks like this one except mine didn't come with that four port usb hub board. It works pretty well and it's less than $40. It looks somewhat durable. My intentions for it were to make an in-dash car pc with a 7" screen, without having to use a Lilliput or anything like that. Unfortunately, lack of funds halted that project dead in it's tracks.
Kids, don't play with too many knives! -Crack Stuntman
kibble is offline   Reply With Quote
Old 04-09-2009, 07:57 PM   #4
Kibble have you sill got the LCD then? And or looking to sell it?
Old 04-09-2009, 08:31 PM   #5
kibble's Avatar
Well, it's not a vga LCD or anything, it needs to be interfaced to a controller board. The only connector on it is a 40 pin, digital 18bit input.
Old 07-16-2009, 03:13 AM   #6
bongta029 is an unknown quantity at this point
I bought 2 of those from ebay and broke the first one while installing it, and 2nd one I broke it while I was taking it off from double sided tape
calibration worked before I taped it on front of the screen. I had 6.2" since my screen was only 6". Now I'm debating if I should re-order the screen for $40 or buy a touchpad.
Touch screen was pita to use while driving on my pop-up screen which was on top of my center console.
bongta029 is offline   Reply With Quote
Xbox Media Center 2.0 and Touchscreen blckwdw General MP3Car Discussion 31 05-12-2009 09:51 PM
knobs/buttons vs touchscreen? impala454 General Hardware Discussion 31 11-27-2008 02:06 AM
Lilliput 8" Touchscreen broken waltwalt LCD/Display 3 04-27-2006 12:37 PM
Broken Motorized Touchscreen Mechanism ajscomp372 LCD/Display 2 04-24-2006 08:21 PM
FS broken lilliput Touchscreen. £30 UK only bertybassett Classified Archive 8 08-09-2004 09:20 AM
