Quote: Originally Posted by
WuNgUn
Power the hub directly thru it's jack with your regulator, instead of thru the extension...
Whoops,now I understand the problem. THe USB spec only sends 500 milliamps per port. Your extension cable probably only outputs the same maximum current which is not enough to power your hub (500 mA x 8 = 4 amps). You need to power the hub directly as I was suggesting. So try the above approach, initially from your regulator directly or if that is not enough, build another or buy one with more grunt.
