Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 07-17-2009, 08:26 PM   #1
JuniorGeezer is an unknown quantity at this point
Griffin PowerMate converted to send mouse wheel
My PowerMate was always unreliable. The *#&* driver sucks because it stops working after hibernate and resume. As you can imagine, having no volume control much of the time is no good. To recover, only a reboot helps. Unplugging and replugging of the PowerMate won't do it.
I messed with devcon but gave up because it lists a million devices and I couldn't figure out which one of them was the PowerMate.
I wanted another solution that works with the mouse wheel and software like volumouse.
I took an old Kensington mouse. It turned out that the rotary encoder of the PowerMate is compatible with the controller of the Kensington mouse. Three pins: ground and two signals.
I unsoldered the original controller from the PowerMate. I wired the rotary encoder to the Kensington controller with one half of the original PowerMate cable. I wired the other half of the PowerMate cable to the USB side of the Kensington controller. I also wired the push-switch to mouse button three.
It works, using volumouse I got volume control on mouse wheel with my modified PowerMate.
If you try to repeat this, be sure to use a mouse that uses a three pin, electrical rotary encoder as opposed to an optical one.
Spray painted PowerMate with mouse controller:
PowerMate controller is removed and the rotary encoder wired using the original cable:
The leftovers. The PowerMate controller is the disk shaped board:
JuniorGeezer is offline   Reply With Quote
Old 07-19-2009, 08:39 AM   #2
csfile's Avatar
csfile is on a distinguished road
nice...I was thinking of hacking up a mouse to make a knob and use volumouse. I just couldn't find the right knob. Never thought of using one of my powermates.
csfile is offline   Reply With Quote
Old 10-22-2009, 10:32 PM   #3
Titansilber is an unknown quantity at this point
Thanks for the inspiration! I hacked up my powermate similar to yours and it works great. I actually bought a 3DConnexion navigator too, but decided to go with the powermate. The 3DConnexion has more potential, but the powermate suited my needs of simplicity.
Titansilber is offline   Reply With Quote
Old 10-23-2009, 11:55 AM   #4
You're welcome. Was your donor mouse an antique (like mine) or of current production?
You may also find AutoHotkey useful for volume control (tested with XP 64 and Vista 64):
http://www.mp3car.com/vbulletin/oper...ml#post1343713
With this solution, my volume control reliability skyrocketed :-). Seriously, it is amazing the hoops you gotta jump through for something as trivial as a hardware volume knob.
Old 10-24-2009, 05:00 PM   #5
I'll have to try the Autohotkey. And yes I hacked up a pretty old mouse.
KNOB WAR : Owners/Users of 3DConnexion vs. Griffin Powermate samantech General Hardware Discussion 31 11-10-2008 03:02 PM
Griffin Powermate with Streetdeck (yet another thread) Nola111 StreetDeck 8 10-28-2007 12:15 PM
Griffin Powermate with Macmini Solo Kernel Panic johnsin MacCar 2 12-02-2006 12:54 AM
FT: griffin powermate fallnangel Classified Archive 5 01-18-2005 11:48 PM
Scroll wheel on a mouse mikeinsanmarcos General Hardware Discussion 1 04-13-2002 11:52 AM
