Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 08-15-2009, 07:23 PM   #1
Bigseven74's Avatar
Bigseven74 is on a distinguished road
DOUBLE DIN LILLIPUT 7 question
DOUBLE DIN LILLIPUT 7" 629GL-70NP/C/T
I'm looking into adding this to my next carpc build how do you go about installing this thing (mount) into your double din slot ? thanks guys I just dont see how it will stay in its' slot.
Bigseven74 is offline   Reply With Quote
Old 08-15-2009, 07:26 PM   #2
PaulF's Avatar
PaulF is on a distinguished road
Use the holes on the sides to bolt it into the car's bracket.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 08-15-2009, 07:28 PM   #3
Bxsteez will become famous soon enough
I just used a double din metra kit for my car and it worked out great. Not sure what kind of car you have but u might want to check out bybyte.com They have preassembled dash pieces.
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Bxsteez is offline   Reply With Quote
Old 08-15-2009, 07:46 PM   #4
Bigseven74's Avatar
I will install it in a Boxster S
Old 08-15-2009, 09:14 PM   #5
theonlykid is on a distinguished road
Check here
http://www.metraonline.com/products.aspx
but I dont think they make one for a Porsche.
theonlykid is offline   Reply With Quote
Old 08-15-2009, 11:29 PM   #6
Bigseven74's Avatar
where should i start...
the boxster (986 & 987 series) have two very different dashboards. The 986 series was split into 99-02 dash and 03-04 dash. I have a 03. In the 986 series porsche used a standard din system. I 05-till they use there own system. (as I writing this I now realize what i need) the last time i did a install on my 01 Boxster S I only needed to add the mounting kit. i dont think a need anything else. The probelm i ran into with my 01 was there was a gap in between the air vents and the first din. I dont yet have my 03 in. when it comes in I think that problem will not happen because of the change in dash in 03.
if i run into a problem, i know where to come.
thanks guys,
Old 08-15-2009, 11:40 PM   #7
I would start by measuring. The frames are 177 x 107 x 77 W x H x D. You can get just a frame for $30 if you want to test fit one. The metra kits are nothing more then a piece of moulded ABS plastic. If it comes to it a good customization shop will be able to fab one up for you.
Old 08-16-2009, 06:47 AM   #8
Bigseven74's Avatar
I will do. I not to worried about the metra kits like this one on ebay. If it comes down to where I need to order one... I will. I installed on my old Boxster, in din slot one, a single din 7" touchscreen. It left me with a small gap. i think (i dont have the car yet i'm waiting on it being transported to me) with the 03 boxster the gap will not be there because there a thin cup holder up there now. I found a ebay pic of a 03 Boxster S. The dd Lilliput that I'm buying seems to have enough trim around it, but until I have both car and screen I will have too wait to see.
Infiniti g35 Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen? rijotech Newbie 3 09-06-2009 12:13 PM
Carputer In Dash Double DIN cases - exist? BFarm Newbie 18 08-28-2009 06:16 PM
mounting a Lilliput 629GL-70NP 7" in a single din dash snoboarder2k6 LCD/Display 1 07-07-2009 07:12 PM
2001 Jetta Single DIN to Double DIN??? thisbejoe7 Newbie 0 06-30-2008 10:42 AM
2 Single DIN units in a Double DIN mount Dondro Newbie 5 06-22-2007 03:21 PM
