Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 09-03-2009, 08:48 PM   #1
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
P.C. won't boot with touch screen plugged in???
My p.c. used to work beautifully but decided to change up the dash layout and add a cd player. I was using the Tview/Dynamix 816 and have recently changed to a Xenarc MDT-X7000. Whenever I boot the P.C. with the Xenarcs USB plugged in it hangs on the post screen anywhere from 5-10min; then it pops up "missing GLDR file ...resetting drive" and hangs there until the p.c. is powered down. If I power down the monitor or unplug the USB the P.C. boots great and works as should after the USB is plugged back in. At first I thought touch screen drivers, so I reinstalled them, I have reinstalled the OS (XP home) because a few weeks ago I was getting an update and the battery in the car died and I occasionally got a missing Bootmgr file but I fixed that with the repair utility, and I thought this could have been an issue related to that but it doesn't seem to be. I kept having the issues so I decided to try a different OS and installed Vista 32 but the problem sill persist. Any advice would be greatly appreciated.
Thanks Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 09-03-2009, 09:06 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Check the BIOS and make sure USB Boot is disabled, or at least lower in the boot order than the HDD.
That model has the DVD drive, and it sounds like the PC is trying to boot from the DVD drive in the MDT-X7000 instead of the HDD.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-03-2009, 10:19 PM   #3
boomintrac's Avatar
Thanks for the quick reply, I will check the bios. I think that the BIOS is set to boot only from the HDD with no secondary boot options, but I might be wrong I cant remember.
Aron
Zapco DSP-6
Zapco 500.1-Sub
Old 09-04-2009, 08:04 AM   #4
If your CMOS battery is flat, it may have reset BIOS settings to defaults.
Just a thought.
Old 09-04-2009, 03:52 PM   #5
eribs4e is on a distinguished road
You mention you added a cd player...is it by chance a USB one? If so perhaps it is causing the problem and not your monitor. If it is a USB one try powering it directly and not through the USB connection.
Again, if it's not USB based then nevermind...
eribs4e is offline   Reply With Quote
Old 09-07-2009, 09:17 PM   #6
boomintrac's Avatar
Sorry for not getting back to this thread, I had took holiday over the weekend.
The BIOS was good and only set to boot from the HD
I believe it is more to do with the CD drive more then the touchscreen as I never had the issue before. Maybe I'll look through Device manager to see what the P.C. sees it as.
Thanks Aron
Zapco DSP-6
Zapco 500.1-Sub
Boot up 3 times @ 800x600, 4th time at 800 x 480??? RedGTiVR6 General Hardware Discussion 30 10-31-2008 09:31 AM
Review: TView 8" LCD Widescreen Touch Screen 56k Beware AcuraTLFan The Review Palace 26 01-30-2008 03:01 PM
Lilliput 8" touch screen backwards - FC4 DJBigShow Linux 9 08-04-2006 03:43 PM
Lilliput touch screen Help..please avn128 LCD/Display 2 08-03-2006 05:20 PM
