Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 09-16-2009, 03:56 PM   #1
timebandit is an unknown quantity at this point
Steering Wheel Controls -> USB question
Hey guys, I found this part online and had a question about it. My
plan is to completely replace the head unit in my car with a computer,
so I was wondering if I could still use this part even after removing
the head unit. Basically my question is that whether the adapter is
receiving its signals from the steering wheel or from the head unit..
If the head unit is gone, will the buttons on the steering wheel still
work and send a signal to the adapter?
http://indashpc.org/new/adapters/car2pc-maz.html
Thanks in advance!
timebandit is offline   Reply With Quote
Old 09-17-2009, 01:46 PM   #2
afterdigital's Avatar
afterdigital is an unknown quantity at this point
@timebandit
i'm wondering the same thing. you may want to look over here it seems that with the right wires soldered in may provide the results we are looking for...
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline   Reply With Quote
Old 09-17-2009, 01:54 PM   #3
I couldnt really find anything useful there related to our problem.. I might order it, plug it in, and see the outcome.. Because im SURE that there are many people out there with the same question.. Either that or email the vendor and see what he says..
EDIT:
Just emailed vendor, hopefully will get a response soon!
Old 09-17-2009, 02:41 PM   #4
Got an answer!!
Hi,
Our device works only when OEM headunit present,
Hope this helps,
Dmitry/
-----Original Message-----
Sent: Thursday, September 17, 2009 11:02 AM
To: inquiry@car2pc.com
Subject: customer from Car2PC WebPage
Hi,
I had a question about your product.
My plan is to completely replace the head unit in my car with a computer, so
I was wondering if I could still use this part even after removing the head
unit. Basically my question is that whether the adapter is receiving its
If the head unit is gone, will the buttons on the steering wheel still work
and send a signal to the computer?
Thanks!
Old 09-17-2009, 03:29 PM   #5
trinybwoy is an unknown quantity at this point
i would recommend this...
http://www.rcjoycon.com/base_3/menu_...om_board_idx=9
i use it in my 2006 mazda 6.
i have the audio steering wheel controls mapped to it.
it supports up to 10 buttons.
i paid $32 . money WELL spent.
you will have to locate the two wires that run from the steering wheel to the radio, hijack those and tap them into the joycon.
do some configuring , and presto.
trinybwoy
trinybwoy is offline   Reply With Quote
Old 09-17-2009, 03:43 PM   #6
Hmm.. That seems interesting, I have a few questions though..
1) Does there have to be a Software running in the background all the time?
2) How do you map the keyboard to centrafuse? Does centrafuse have "keybaord shortcuts"?
Old 09-17-2009, 03:48 PM   #7
1) no 3rd part software is running . the device identifies itself as a usb Keyboard.
2) (a)to program keys into the device , you will use the bundled software. (once the keys have been programmed, u can exit the software and never use it again. until u want to reprogram.
(b) yes centrafuse has kboard shortcuts.
you can assign up to 3-4* keystrokes per "key" pressed.
eg. i have the volume down button on my wheel mapped to "control-alt-delete"
i have the volume up button mapped to "alt+tab"
etc...
trinybwoy
Old 09-17-2009, 03:54 PM   #8
AAH alright.. makes total sense.. Another question for you then, where ALL the buttons on ur Mazda-6's steering wheel coming down to a single socket? in which u plugged this into? or did you need more than one of these to map ALL your buttons on your steering?
Old 09-17-2009, 04:08 PM   #9
all the buttons came down to two wires that connected to the back of the radio.
if i remember correctly, is a black and a green wire.
it has been a long while since i have been at the back of the radio.
i will look for some mazda radio wiring for u.
wut model car do u have?
trinybwoy
Old 09-17-2009, 04:10 PM   #10
Im actually driving an 04 RX-8.. All parts for my CarPC are here and im hoping to get some setting up done this weekend.. But now that this item has arrised, I might be waiting another week to get it setup with the system too.
Old 09-17-2009, 04:13 PM   #11
http://forum.mazda6club.com/index.ph...=post&id=27164
u will have to register on the forum in order to see the diagram .
the color of the wires are actually red/black and green/white.
to view other wiring diagrams for mazdas check out post #2 here...
http://forum.mazda6club.com/index.ph...&#entry1070225
trinybwoy
Old 09-17-2009, 04:23 PM   #12
dude - that sounds amazing!!! i have a cadillac CTS and i think i know which wires are for the steering wheel. Would it work on my car? Could the website help me if i run into problems?
Now it is recognized as a keyboard - i would like to control the volume and mute. Is this feasable?
Also the link shows the product - but how do i buy?
thanks again
AD
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
Finished Project
Car Hacking
WorkBlog
Video
Old 09-17-2009, 04:23 PM   #13
great! i just registered, looking forward to the diagrams.. Do you think they are the same for all mazdas?
Old 09-17-2009, 04:27 PM   #14
Hey afterdigital, you can order them on ebay from here.. Ill let you know how it goes when I plug them in.. Would really appreciate it if you could do the same!
http://cgi.ebay.com/CarPC-JoyCon-Ste...ht_4044wt_1165
Old 09-17-2009, 04:33 PM   #15
thanks again
AD
i got mine from ebay.
it will work with any steering wheel buttons/or any buttons that operate using resistive current.
if you can map a shortcut key to mute and volume it will work.
i know if u use 3rd part apps such as winamp and centrafuse, it will work.
the gentleman who sells them is VERY helpful!
customer service is top notch!
simply email him and he will respond very quickly
trinybwoy
Help me understand Steering Wheel Controls Oman4x4 General Hardware Discussion 1 11-10-2008 06:21 AM
2003 Durango Steering Wheel Controls Joe_Cool Input Devices 0 08-08-2007 09:47 AM
Sports Steering Wheel & Input controls DrunkMonkey Input Devices 0 07-11-2007 12:38 AM
Re-engineered steering wheel controls for Creative Zen Touch mp3 player. darkone_05 Worklogs 2 05-23-2006 12:56 PM
USB RF compatible Steering wheel controls god_of_cpu Input Devices 4 04-19-2005 05:03 PM
