Quote: Originally Posted by iPal
i believe you may use left/right and hold down left/right as deferent setup...
so you may use left/right for volume... then hold down left/right for sub if you want to...
With the current win32 drivers release you can use 4 out of 6 commands without any conflicts. However, when you assign down and rotate as well as the click commands, when you release down rotate you will click as well.
You can have rotate and down rotate or rotate and click/long click. trying to have click/long click and down rotate will cause problems. Should be fixed in the next driver release.
Another note. The software for controling the powermate will only control windows that are in focus. If you want Copilot on top and your powermate to control winamps track forward and backward functions you will have to use Girder and a few plugins to make it work.
To get the girder hack to work you have to use ANOTHER hack to make girder recognise the powermate. (the plugin that is supposed to recognise the powermate natively with girder is currently broken.)
In short. Powermates are a pain in the *** to set up properly. If anyone wants help scripting girder to control a powermate, send me a PM and I'll be glad to help, They're worth the trouble.
