Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 02-02-2004, 06:42 PM   #1
Touch screen function: I want two Xenarc screens showing media engine and Deltadash
Will the USB touch screen work with two screens at the same time? I would like to have Media engine on one and delta dash on the other. It is for a Subaru BTW.
Delta Dash shown in this thread http://www.mp3car.com/vbulletin/engine-management-obd-ii-engine-diagnostics-etc/18764-obd-connector-2004-subaru-sti.html
BrotherMaynard is offline   Reply With Quote
Old 02-02-2004, 06:47 PM   #2
Here is Media Engine just to see what they look like right next to each other...
Old 02-02-2004, 08:35 PM   #3
SMKFree
liquid_smoke's Avatar
need more info on your setup. If your using an all nvidia dual mon solution, there are options to set which monitor each program will open on.
liquid_smoke is offline   Reply With Quote
Old 02-02-2004, 08:41 PM   #4
SMKFree
Old 02-02-2004, 09:51 PM   #5
The video card is the cheapest part of the problem... I figured any dual-head will do. I don't however know if the touch screens will work on both.
Old 02-02-2004, 10:00 PM   #6
SMKFree
http://www.mp3car.com/vbulletin/lcd-display/19588-2-lcd-screens-w-touch.html
also any dual head probably wont do, well it probably will, but they are not all equal. ATI's drivers suck *** for dual head, i would go with nvidia.
Old 02-02-2004, 10:51 PM   #7
total assumption here but I would assume plugging in 2 usb touchscreens would be like having 2 mice in your system: as long as you don't use both at the same time you should be fine, otherwise they will fight each other for the cursor position. If you have a laptop with a touchpad and a mouse you can see what I'm envisioning, this is what I'm basing my assumption on.
Bobby Digital is offline   Reply With Quote
Old 02-03-2004, 01:31 AM   #8
SMKFree
your assumtions are correct.
Old 02-05-2004, 03:40 PM   #9
The problem i see here is what will the PC think of your touchscreen dimension? Obvious answer is that both are configure onto the same axis. That mean if you had your desktop screen longer or wider, you would not be able to operate the longer part of the screen. Both touchscreen will only able to operate the left side of the screen. Hope I explain this in a matter that can be understood.
nl4jy is offline   Reply With Quote
Old 02-05-2004, 03:53 PM   #10
SMKFree
This isnt a problem, if you look at the latest version of the touchscreen drivers for lillyput and GAIN screens, there are mapping options for using more than one monitor. So, the drivers are made with this in mind. Very similar to using two wacom tablets on one PC.
Old 02-05-2004, 04:00 PM   #11
Cool, I was wondering about that. I figured you'd have to have a secondary program or do some reg hack to tell the PC that the second mouse/touchscreen started its x access at (e.g.) 801 instead of 0.
Almost a Ghost is offline   Reply With Quote
Old 02-06-2004, 03:25 AM   #12
Mazda6PC's Avatar
I think the best solution would be to build a second system with some spare parts you can find. Put in only the money it would cost to buy a new PIMP video card and run the system as light a possible(fast booting). This is what I’m planning to do in a few days with my tax rebate check. This way the system boots faster and is dedicated to only digital dash. You don't have to worry about the configuration and all of that mouse crap. If you want you will not need a keyboard and a mouse at all. If you are smart forget the touch screen all together and there is where you will save some big money for the system! This is what I'm going to do...
MVC www.mobiletvsystems.com/
Check out the shop if your in the Maryland DC VA Area
2004 Mazda 6s 3.0L
Epia Via M-1000 512MB
Opus 150W
Samsung 80Gb ATA133 7200RPM
New XenarcTSV
Mazda6PC is offline   Reply With Quote
Old 02-06-2004, 11:31 AM   #13
Thanks for the update. I haven't download any drivers for my carputer for a long time and didn't know that they update it to include this function.
Old 02-08-2004, 04:41 AM   #14
Hi,
I am also a Subaru-driver (WRX STi Euro-version), how well does the Deltadash software work with touchscreen?
I will but the software to keep track of my engine because of my mods...
/L-O
loscooby is offline   Reply With Quote
