Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 03-17-2004, 11:07 AM   #1
Dim Lilliput 7"
Just a quick question, have done a but cannot see an answer for this.
I have a Lilliput 7" Touchscreen running off a Dell Latitude laptop. The screen seems to dim 2 seconds after you turn it on! especially when using media engine, checked that dim at night option is not checked.
Have tried Auto setup on the screen but it goes to a nice picture then dims straight after. Also played around with the Brightness but can't get the right clear image that appears for only a second with Auto setup.
Any Idea's?
Cheers...
dw_uk2000 is offline   Reply With Quote
Old 03-18-2004, 06:52 AM   #2
FreeDrive Creator
CdRsKuLL's Avatar
have you tryed the monitor on another source ?
have you tested that the brightness setting on the dell doesnt effect it ? (press fn+uparrow) ?
in the dell bios you can also set brightness in there.
only things I can think of.
sorry
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 03-21-2004, 08:11 PM   #3
I had the same problem in bench testing. What I did was to set the time for the night time skin to switch on at a later time. Must be a bug in the program.
UOTE=dw_uk2000]Just a quick question, have done a but cannot see an answer for this.
Any Idea's?
Cheers...[/quote]
Twowire is offline   Reply With Quote
Old 03-23-2004, 03:24 PM   #4
Adjust brightness
Any Idea's?
Cheers...
Press menu, select Graphic, select brightness, you can adjust brightness by press menu and volume botton. You can also adjust contrast and RGB color.
carmate is offline   Reply With Quote
Old 03-23-2004, 03:27 PM   #5
Cherub211's Avatar
Try benchmarking the screen on another computer without any specific programs, then see if it does the same thing. This will atleast rule out the laptop if it's not the problem.
Cherub211 is offline   Reply With Quote
Closed - Lilliput 7" XGA Touchscreen GROUP BUY imi1232000 Classified Archive 281 04-14-2004 10:29 PM
In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen JonX69 LCD/Display 2 03-06-2004 01:22 PM
Sis650 and lilliput 7": how to set 16/9 pianetadigitale General Hardware Discussion 0 02-15-2004 05:03 PM
exact outer size of 7" lilliput touchscreen? cotwild LCD/Display 2 01-08-2004 12:43 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
