Quattro, what OS are you using in the Xbox? I believe if you go w/ Gentoox you can just use the Xbox controller. Not 100% though. However, if you plan on using XBMC or XBMP, I don't think there is any external way of varying the volume w/o using the headunit. However, that amp looks to have volume control built in, so that may be the way to go...I hope I helped a bit.
