Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 07-16-2007, 06:07 AM   #151
simbau is an unknown quantity at this point
Quote: Originally Posted by simbau View Post
Thank you.
I try to put the value to 500 ohm. I will make to know you!
Simone
I have verified with the resistor from 500ohm, but I have not obtained good I turn out to you.
The software SWC the behave myself optimally, but for the values of the key enter and of key + he does not succeed to pick up marks them, because the values to are too much similar.
It tares the values optimally for the key enter and volume “+” wraps it of the values is too much near from 100 90.
How I can resolve this my problem?
Simone
simbau is offline   Reply With Quote
Old 07-16-2007, 01:37 PM   #152
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Each time you change resistors you should calibrate the joystick in control panel. See if that helps.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 07-16-2007, 04:57 PM   #153
Sure!
I have always carried out the setting of the joystick on the panel of the control. I have always calibrated the joystick with the control panel, every time that I carried out the change of resistance.
I use joystick 2 axes and 2 buttons, I bore the keys of the sterring wheel command, and the joystick turns out centers them!
Software SWC reads to equal values for the key Volume + and that one of the key enter, is too much similar!
SWC reads the remaining values of keys correctly
Help!
Simone
Old 07-17-2007, 07:58 AM   #154
Curiosity's Avatar
What numbers do you see for each button and with no button? Maybe that can help me figure out what's going on.
Old 07-17-2007, 09:50 AM   #155
The values of the resistances of mine steering wheel command are:
“ENTER”, “+” and “-” switch resistance
All switches released (OFF): 4700 - 5600 kΩ I read 5,17k
A) “ENTER” switch (1) pushing on (ON): 50 - 60 Ω I read 0,06K
B) “+” switch (2) pushing on (ON): 120 - 140 Ω I read 0,13K
“-” switch (3) pushing on (ON): 220 - 260 Ω I read 0,24K
“MODE”, and switch resistance
All switches released (OFF): 4700 - 5600 kΩ I read 5,17K
C) “MODE” switch (4) pushing on (ON): 370 - 460 Ω I read 0,42K
D) witch (5) pushing on (ON): 680 - 820 Ω I read 0,7K
switch (6) pushing on (ON): 1400 - 1700 Ω I read 1,57K
SWC reads the values of enter and those of volume + or - too much near.
THANK YOU
SIMONE
Old 07-17-2007, 01:10 PM   #156
Curiosity's Avatar
Are you using babblefish? That thing is goofy.
What values do you get for each button in SWC?
Old 07-17-2007, 04:11 PM   #157
Excuse for my English! I use the translator of google!
Swc reads the following values: with resistor of 500ohm
key ENTER: 100 - 100;
Key +: 100 - 96..98;
key -: 96 - 92;
key mode: 86;
key > 72;
key > 60;
I have problems to shape key + and the key enter, the key - he does not create problems!
Thanks for your patience… I am in difficulty also with the language!
Simone
Old 07-17-2007, 05:23 PM   #158
Curiosity's Avatar
Yoda-like are translators. Suck they do.
So the connection to the steering wheel is like this right?
+5V ---<500ohm>---- Steering wheel wire 1
Joy X ---Steering wheel wire 1
Steering wheel wire 2 ---<500ohm>---Gnd
I'm having trouble with math today. Between 50 ohms and 120 ohms should be enough of a difference. Anyone else that can help?
Edit: I think a 100 ohm will work better:
Steering wheel wire 2 ---<100ohm>---Gnd
Old 07-17-2007, 05:49 PM   #159
I use this system:
pin 1 --+----------+
........ Z..............|
. . . . . Z 500 ohm ==== swc
pin 3 --+----------+
pin 6 --+
......... Z
........ Z 500 ohm
..........Z
pin 8 --+
I try with resistor from 100 ohm
Thank you
Simone
Old 07-18-2007, 08:46 AM   #160
Curiosity's Avatar
That may be very noisy because it is not grounded. Try this.
pin 1 --<500>---+---SWC1
pin 3 -----------/
pin 4 --<100>--------SWC2
Old 07-18-2007, 09:56 AM   #161
pin 3 -----------/
ok I try your solution!
thanks you.
Mine swc it is composed from a single cable:
Wheel-------swc============
Simone
Old 07-18-2007, 11:18 AM   #162
Curiosity's Avatar
You should have 2 wires so you can complete the circuit, unless it is grounded somewhere. The electricity must flow from source to ground somehow or the values will not change. For example (5V-<500ohm>-X) X=5V, but (5V-<500ohm>-X-<500ohm>-Gnd) X = 2.5V
Old 07-18-2007, 12:35 PM   #163
excuse but I want to say:
I have two cables that go to the sterring wheel.
Only cable composed from two cables.
A positive one and leads current to the resistors the other transmits the values!
I have a doubt the values of the commands of the steering are read for +12v… the port game joystick has only +5.
It is not that values +5 to the resistors of series give annoyance?
I try with your solution!
Thank you
Simone
I MUST ONE PIZZA AND BEER TO YOU!!
Old 07-18-2007, 05:02 PM   #164
pin 3 -----------/
Your solution does not work!
The gameport of the creatives sound blaster it sees the “joystick” but in the control panel, I cannot make the configuration,
as soon as I press the keys does not recognize the joystick.
Simone
Old 07-19-2007, 11:55 AM   #165
Curiosity's Avatar
That is not good. I guess your old way works better, but I don't see how. Maybe try resistors a little higher or lower to see which works better?
steering wheel touch screen monitor?? thecar-puter LCD/Display 43 07-11-2008 04:56 PM
Keeping steering wheel controls with new HU pogue1000 General Hardware Discussion 4 01-14-2004 01:24 PM
Steering wheel controls thru serial or usb? welthqa General Hardware Discussion 9 01-14-2004 01:20 PM
Buttons on steering wheel to work with computer? slboytoy Input Devices 4 10-21-2003 01:40 PM
FS Pioneer Steering Wheel Remote CD-SR80 Sh0cker Classified Archive 5 10-02-2003 10:48 PM
