Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 09-10-2007, 01:16 PM   #181
swift_gti is an unknown quantity at this point
Curiosity:
Thanks so much!
I hooked up the joypad to my Sony adaptor I purchased for my car as you described and IT WORKS FLAWLESSLY!!!
I did as you suggested and checked for voltage across the the ground of the joypad and the ground of the Sony adaptor and I found 0.13v... could this cause a problem in the longrun ? Is there anything I can do about it?
I only found this voltage when the laptop was powered using the incar charger, it was 0v when on battery..
I'm soooo pleased it works, thanks for your help!!!
swift_gti is offline   Reply With Quote
Old 09-10-2007, 02:12 PM   #182
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
It should be fine. If it was like 1-50V it would have been a big problem. 0.13V may cause a little ground hum at high volume. If so, you may want to ground the laptop better.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 09-10-2007, 02:31 PM   #183
Awesome, just wanted to double check I wasn't slowly cooking my ECU or anything
Thanks for all the advice, I really owe you one
Old 09-11-2007, 12:24 AM   #184
EBJUSTIN
Quote: Originally Posted by Curiosity View Post
With a normal ADC like the K8055 it's pretty simple and more stable than a gamepad. I've used both. All you need to do is connect 1 wire to 5V off the device (I'm sure it's there) and the other wire to the analog input. If it jumps around with no buttons pressed, just put a 100K resistor between the input and ground. That's all you need.
I've previosly gotten this working when I used a soundcard with an integrated gameport. I'm not too concerned about hooking up the Sony X4S to the K8055 but I am curious about the amount of DLL modifications required.
How much .dll tweaking is required for windows to recognize the K8055 as a gameport device?
My Celica Carputer Install
EBJUSTIN is offline   Reply With Quote
Old 09-11-2007, 01:49 AM   #185
Curiosity's Avatar
There are a few K8055 plugins for frontends and some have source. Just search the forum.
Old 09-13-2007, 10:28 AM   #186
gurob's Avatar
gurob is an unknown quantity at this point
please, who knows how to calibrate the SWC? what to do when it asks center position?
gurob is offline   Reply With Quote
Old 02-03-2008, 04:33 AM   #187
sgtpepperaut is an unknown quantity at this point
is there something like standard resistances for steering wheel buttons?
sgtpepperaut is offline   Reply With Quote
Old 05-04-2009, 08:19 PM   #188
jarepa is an unknown quantity at this point
This scrip works excellent. Zorro is an excellent coder (well we all know that since he made phoco).
But I have an annoying issue: when the computer goes to standby, it upset the scrip and gets a red X and it shows "ERROR - Joystick Connection"
I'm using an eliminator gamepad. Did anyone experienced the same?
Any help its really appreciate.
jarepa is offline   Reply With Quote
Old 05-07-2009, 07:31 PM   #189
Pls Help
Bump.
No one helping with the "ERROR - Joystick Connection"
Mike.
Old 05-11-2009, 02:56 PM   #190
extraaha is an unknown quantity at this point
There is CarPC JoyCon that converts steering wheel controls into USB keyboard.
Resistance output steering wheel controls can be directly connected.
extraaha is offline   Reply With Quote
Old 06-09-2009, 08:24 PM   #191
Sponge's Avatar
Sponge is on a distinguished road
Anyone still have the SWC software? Links are dead :/
Sponge is offline   Reply With Quote
Old 06-17-2009, 10:16 AM   #192
Punx0r is an unknown quantity at this point
I have been plaing with this recently and have a copy of it I could email to you (it's 4.8Mb).
Punx0r is offline   Reply With Quote
Old 06-18-2009, 03:02 PM   #193
webdaniel101 is an unknown quantity at this point
Talking SWC software?
Anyone still have the SWC software? Links are dead!
Could some one email it to me?
Thanks so much!!!
webdaniel101 is offline   Reply With Quote
Old 06-21-2009, 06:03 PM   #194
Sponge's Avatar
Arrow
Thanks Punx0r for getting me the file!
I've uploaded it to megaupload for anyone else that wants it.
http://www.megaupload.com/?d=9V1O2ASW
God of cpu, if thats a problem, let me know and I'll pull the link.
Old 06-23-2009, 12:14 PM   #195
Thanks for uploading the file!
steering wheel touch screen monitor?? thecar-puter LCD/Display 43 07-11-2008 04:56 PM
Keeping steering wheel controls with new HU pogue1000 General Hardware Discussion 4 01-14-2004 01:24 PM
Steering wheel controls thru serial or usb? welthqa General Hardware Discussion 9 01-14-2004 01:20 PM
Buttons on steering wheel to work with computer? slboytoy Input Devices 4 10-21-2003 01:40 PM
FS Pioneer Steering Wheel Remote CD-SR80 Sh0cker Classified Archive 5 10-02-2003 10:48 PM
