Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 09-04-2004, 09:47 PM   #46
ddogg_777's Avatar
ddogg_777
Oh, I thought you were getting 2, 5, and 12V when you pushed buttons. I guess if you have TX+/- then those are digital.
Quote: Originally Posted by DjBac
I have the controls out of the car and testing them with a 12V power supply...
They have only 4 wires...
ACC, GROUND and TX+/-
I've used PAC SWI-X and IRMan but with no result!!
Voltage WON'T change!!! That is the problem!!!
Is there a way that the control don't work??
I have an aftermarket HU and I don't know!!!
ddogg_777 is offline   Reply With Quote
Old 09-05-2004, 02:46 AM   #47
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Does the PAC SWI-X work? Easy way to test: Just look at the IR emitter through a digital camera/video camera. They all pick up IR. To test the IRMan, use any other remote from a TV or stereo. If both work, I have no more ideas.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is online now   Reply With Quote
Old 09-05-2004, 05:37 AM   #48
DjBac's Avatar
DjBac is on a distinguished road
I've tested SWI-X and works fine!!
I use IRMan with another remote, so it is just fine!!!
If my controls are digital, how can I make them work?
DjBac is offline   Reply With Quote
Old 09-05-2004, 08:23 PM   #49
Curiosity's Avatar
So if you use a TV remote you get events in Girder, and the SWI-X flashes the IR emitter when you press buttons on the steering wheel but you get no events in Girder? Maybe incompatible IR signal or something? Anybody??
Old 09-07-2004, 10:16 PM   #50
c a m a r o is on a distinguished road
sorry i didnt read this whole thread. i couldnt stop laughing after i looked at god of cpu's site. ...junior roflmao.
c a m a r o is offline   Reply With Quote
Old 09-08-2004, 07:28 AM   #51
DjBac's Avatar
IRman works...
SWI-X works because when I change the resistor input it sends IR signals!!!
So either my ST/W controls malfanction or they are digital..
Is there a way to interface them??
Old 09-08-2004, 08:57 AM   #52
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
If they are digital, you could just open them up and rebuild them to be analog. A bit of soldering and a couple of resistors....
I think the digital protocol will be proprietary, otherwise, you could hook them up to a serial port...
JC-S60 is offline   Reply With Quote
Old 09-08-2004, 09:42 AM   #53
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
DjBac,
As was mentioned before, the steering wheel controls actually work based on changing current, not on changing voltage, although voltage does change with the current. They work by changing the resistance of a wire that goes to and from the head unit. The real way to test for this is to hook up your voltmeter, but set it to check resistance. (Testing for voltage will only work if you tap into the lines as they are hooked up to your head unit cause this is where it gets the power from) You should hook the ground going into the controls to one wire on your voltmeter and one of the TX things you have to the other one. Your resistance reading should change when you press a button on the steering wheel. If it doesn't you either have the wrong wires or it's just using some other way thats not going to work.
Since you said you have gotten the PAC SWI-X to work, my method *should* also work. I don't believe that the SWI-X supports and other format then the resistance changing one.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 09-08-2004, 09:51 AM   #54
cheap custom title
JC-S60's Avatar
If I understood a previous post, he'd gotten it to work by using a resistor, not the steeringwheel controls...
Old 09-08-2004, 11:47 AM   #55
Curiosity's Avatar
Yeah, god_of_cpu is right. I got totally off track. Get rid of the 12V power supply as well. You don't need it. If your buttons light up when the headlights are on, then that explains the 2 extra wires. Otherwise, I don't know what those are. It could be ground, 12V, left buttons, right buttons?
Old 09-08-2004, 07:08 PM   #56
DjBac's Avatar
Quote: Originally Posted by god_of_cpu
DjBac,
I will try it now!!!!
I am using a power supply because I test them at home!!!!!!
Old 09-08-2004, 07:21 PM   #57
DjBac's Avatar
Still no result!!!
The resistance will stay constant!!!
I now I can do it if I connect each button to SWI-X... But I want to avoid running so many cables through the steering wheel!!!
Old 09-08-2004, 07:27 PM   #58
msb5150 is on a distinguished road
Hey god_of_cpu, I emailed you previously on this subject but got no response, probably from me sending the message to the wrong address, but anyways. Where can I see the source-code to your program to interract with these steeringwheel->joystick remotes?
msb5150 is offline   Reply With Quote
Old 09-08-2004, 11:42 PM   #59
Curiosity's Avatar
DjBac, can you open it up and look at the components? You might figure it out that way. You sure you tried every possible combination of wires? Holding down a button and checking ohms doesn't result in some odd value?
Old 09-09-2004, 02:51 PM   #60
DjBac's Avatar
I have the open because I've changed tthe colour of the leds!!!
I have one wire of the multimeter to the ground and the other either to TX+ or TX- but nothing!!!
steering wheel touch screen monitor?? thecar-puter LCD/Display 43 07-11-2008 04:56 PM
Keeping steering wheel controls with new HU pogue1000 General Hardware Discussion 4 01-14-2004 01:24 PM
Steering wheel controls thru serial or usb? welthqa General Hardware Discussion 9 01-14-2004 01:20 PM
Buttons on steering wheel to work with computer? slboytoy Input Devices 4 10-21-2003 01:40 PM
FS Pioneer Steering Wheel Remote CD-SR80 Sh0cker Classified Archive 5 10-02-2003 10:48 PM
