Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 07-19-2005, 01:29 PM   #121
Micv is on a distinguished road
Anyone figured it out yet ?
Have anyone figured out how to calculate which resistors to use.
I have 6 buttons:
Vol - 54 Ohm
Vol + 147 Ohm
Mode 1036 Ohm
Mute 2007 Ohm
Preset 562 Ohm
^ 300 Ohm
No buttons pushed 5kohm <-- Is this normal
Micv is offline   Reply With Quote
Old 07-20-2005, 08:23 AM   #122
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
I don't think you need any resistor because of that 5k. Try just connecting it to Vcc and the X axis and see of you get different values for each button.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 01-19-2006, 07:59 PM   #123
Jarrod's Avatar
Jarrod
USB doable?
Has anyone managed to get this working with a USB port?
I have attached the wiring diagram for my car, and I have physically tested the resistance and it matches the wiring diagram attached to this post. As you can see, I only have two wires for 6 buttons.
Would it be possible to connect this up to a USB gamepad that has an analog controller? I dont have a gameport on my motherboard, and no header for it either, and I dont want to add a PCI card JUST for a gameport. USB would be perfect as I already have a USB hub up front that I could plug directly into.
Otherwise, I was thinking of ordering the Velleman K8055 kit which has two analog inputs. How would I connect this up to the K8055? I'd imagine I need to run some voltage through it somehow...
Jarrod - Holden VX S!
Jarrod is offline   Reply With Quote
Old 01-20-2006, 12:07 AM   #124
Curiosity's Avatar
With a normal ADC like the K8055 it's pretty simple and more stable than a gamepad. I've used both. All you need to do is connect 1 wire to 5V off the device (I'm sure it's there) and the other wire to the analog input. If it jumps around with no buttons pressed, just put a 100K resistor between the input and ground. That's all you need.
Old 01-21-2006, 01:31 AM   #125
scfountain's Avatar
scfountain is on a distinguished road
If anyone wants a much easier solution to steering wheel mounted controls, i.e. you already have steering wheel controls and want to hook them to your carputer, check out http://www.xkeys.com/custom/xkmatrix.php. There are 2 versions, one is USB, the other is PS/2. The USB can't store multimedia commands, such as volume +/- or track forward/back, according the the tech rep. But the PS/2 one can. And instead of having to write a program or code, you can simply plug a keyboard into it, and the device will learn the keystrokes from the keyboard. Much easier in my book. Costs around $59.
Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
scfountain is offline   Reply With Quote
Old 01-22-2006, 02:07 AM   #126
Jarrod's Avatar
Jarrod
The XKeys solution wont work for most people as most steering wheel controls only have 2 o 3 wires for 6 or so buttons. The board needs an analog input, such as the K8055.
Thanks for the input Curiosity. I think I will just get the K8055 as it would allow me to do much more with its extra inputs and outputs.
Old 02-28-2006, 12:58 AM   #127
civic5zigen is on a distinguished road
I give up on the usb gamepad, can the K8055 work with G35 steering wheel which is providing negative? Do I just tap into my existing wire since I want it to control my stock headunit as well.
civic5zigen is offline   Reply With Quote
Old 02-28-2006, 12:03 PM   #128
Curiosity's Avatar
Check the voltage with and without each button pressed. I think it's in the 0~12v range, so you'll need a resistor divider which is really easy, and the HU should still work fine.
Old 03-01-2006, 02:45 AM   #129
The range is 0~5v, based on the output below what kind of resistor divider do I need? Also, notice the 25(y) wire is acutally a remote control ground instead of +5v or +12v, would it work in this case? Because I plan to use K8055 as trigger for my reverse camera as well where I'll connect to my reverse lamp. When in reverse, it should send singal to RR to bring up the camera skin. I am a nood when it comes to electronic, but seeing my SWC is providing negative and the reverse lamp is pumping positive so I am not sure rather both can work with one K8055 device?
Old 03-01-2006, 05:25 AM   #130
Curiosity's Avatar
I wonder where it gets the power from? It's already set up for a 5v input so you can just connect 22 and 23 directly to a couple anolog inputs without any additional parts. Connecting to a joystick X and Y should have worked as well, though.
Old 03-01-2006, 08:29 AM   #131
ITL
ITL's Avatar
ITL is on a distinguished road
Does a joystick work the same way that this one-wire method for the steering wheel does? Just by changing the resistance on the line?
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 03-01-2006, 11:28 AM   #132
Curiosity's Avatar
Yes. It's just resistors producing different voltages. A joystick uses a potentiometer that's connected to ground and 5V so it can produce the full voltage range inbetween that. The ADC then converts that voltage to a value representing the position of the pot. When you calibrate it, it will assume the center is the voltage when it's calibrating, which should be 2.5V but in this case it would be 5.0V. Normally 2.5 = 0, 0.0 = 127 and 5.0 = -128, but with this it should be 5.0 = 0, 1.7 = 100, 0.0 = 128 or somewhere around that.
Old 03-01-2006, 12:13 PM   #133
ITL
ITL's Avatar
excellent, thanks. Correct me if I'm wrong: I could find the one wire from the steering harness that carries this voltage and "listen in" on it to determine what has been pressed on the steering wheel- based on measuring the voltage. How would one physically tap this line without introducing any interference or further resistance?
500+ full albums
4,000+ video games
old carPC
Old 03-01-2006, 06:41 PM   #134
Curiosity's Avatar
With a K8055 or some PIC, you could connect it direct. There's very little current draw. For a joystick there may be though. A 500 ohm resistor in series with each one should be sufficient.
Old 03-02-2006, 03:11 AM   #135
basically 22 and 23 is providing ground rather then positive voltage as I understand it. So u think I can just tapped into 22 and 23 and connect to the K8055?
steering wheel touch screen monitor?? thecar-puter LCD/Display 43 07-11-2008 04:56 PM
Keeping steering wheel controls with new HU pogue1000 General Hardware Discussion 4 01-14-2004 01:24 PM
Steering wheel controls thru serial or usb? welthqa General Hardware Discussion 9 01-14-2004 01:20 PM
Buttons on steering wheel to work with computer? slboytoy Input Devices 4 10-21-2003 01:40 PM
FS Pioneer Steering Wheel Remote CD-SR80 Sh0cker Classified Archive 5 10-02-2003 10:48 PM
