The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 04-30-2008, 06:20 AM   #16
My Photos: (0)
Quote: Originally Posted by nrgizerbunny View Post
tricky one,
i've got an 05 corolla which has a similar set up. I had to connect ground to one wire and the +3.3v to the other 1 wire (its only a 3 wire system) and the sense to the final wire. Each time you press a switch you are going to get a different resistance coming down across the two ends. Just check to see if you have a ground there anywhere to start off with. If you haven't it doesn't matter which way you connect it up.
Thank you for your answer.
But I don't understand what you said to me. Could you please explain to me better?
Thank you!
electro is offline   Reply With Quote
Sponsored Links
Old 05-04-2008, 05:43 AM   #17
My Photos: (0)
there is one wire that goes to the touchpad, this provides +12v, one wire is ground. Now in my case the remaining wire is used to sense the voltage drop. I think yours has two to sense the voltage drop. hope that makes sense.
nrgizerbunny is offline   Reply With Quote
Old 05-04-2008, 07:19 AM   #18
My Photos: (0)
OK I understand. But I have a couple of questions
First of all the wire from my head unit says +3.3V . Where should I connect it?
Second , There are 2 wires for control and the head unit has only one. What could i do for that?
Old 05-12-2008, 05:44 AM   #19
My Photos: (0)
I would connect the +3.3v to the top rail on the touch pad. ground is one wire and the two sense wires must be the remaining two. I think you have got a facelift loom.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
