Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 07-01-2004, 02:33 PM   #1
chiefsalami is on a distinguished road
connecting IR receiver to EPIA mobo header
Hey all,
Following some direction in some threads here as well as elsewhere, I have wired up an IR receiver to the Fast IR header on my EPIA motherboard. Problem is Windows acknowledges the device, but I cannot get any input read in on Girder. I used the FIR driver for this mobo available on Via's webpage.
I am using Windows XP on this box, and was thinking it might have something to do with the COM ports and how Windows does not assign virtual ports. So I used IRCOMM to achieve this, and have tried all the settings I can with the COM port assigned to the IR device. Still no luck.
Can someone help? Has anyone managed to get a device connected to the motherboard's header to work? I even tried a USB IR device as a test with no luck. I am not sure what to do... Please!
chiefsalami is offline   Reply With Quote
Old 07-02-2004, 04:11 AM   #2
Question
OK, so I was reading and found out that Girder will not support IrDA devices, but another program called IRassistant will. I tried that one, and still no luck. I cannot seem to get the IR port to read anything in.
anyone?
Old 07-02-2004, 09:06 PM   #3
Seth's Avatar
Seth is on a distinguished road
Check this thread out :
http://www.epiacenter.com/modules.ph...c9f60f91ab5a34
and this also (in german) :
http://www.techcase.de/product_info....roducts_id=250
WinLIRC may be the answer.
Hope this helps a little....
Seth is offline   Reply With Quote
Old 07-06-2004, 01:21 PM   #4
thanks for the link... it looks like almost no one has been able to achieve an internal solution (there are many which plug into an external serial port). I managed to make it work this weekend. I used an IR detector available from Radio Shack, along with a capacitor, a resistor, and a diode. You also need a voltage regulator to work with the detector.
WinLIRC WAS the answer, but I only figured that out after a bunch of reading and came across the fact that Girder does not support IrDA. After a bunch of tweaking with WinLIRC settings, it works! And with a plugin to Girder, now I have Girder controlling my remote actions.
Old 07-06-2004, 02:55 PM   #5
Seth's Avatar
I'm glad you figured it out.
Cheers.
Old 07-06-2004, 03:13 PM   #6
mutilator's Avatar
mutilator
got any pics, and circuit diagram? to make it easy for a circuit nooooob like myself?
tom.
Http://www.StairBox.com
mutilator is offline   Reply With Quote
Old 07-08-2004, 08:43 AM   #7
Fher's Avatar
Fher is on a distinguished road
http://cmail.info.kuzbass.net/%7Enav/WinLIRC.htm This might work too, I use to have it working with my gigabyte 7KKXP mobo IRda headers
Fher is offline   Reply With Quote
Old 09-02-2004, 08:16 PM   #8
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Yea break it off
antimatter is offline   Reply With Quote
IR serial port receiver - where to buy toadster123 Input Devices 16 08-04-2004 10:17 AM
Connecting usb ports on the mobo header.. toadster123 General MP3Car Discussion 3 02-26-2004 04:26 PM
EPIA mobo and DVD playback nadir_s General Hardware Discussion 5 01-08-2004 09:18 PM
hiding ir receiver in air vent grandamp3 General Hardware Discussion 3 11-17-2000 01:12 PM
Mobo IR connectors blkdragon6 General Hardware Discussion 6 07-07-2000 02:23 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
