The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 09-09-2004, 02:03 AM   #1
My Photos: (0)
Endless calibration.
Hi there!
I have a touchpanel I ordered from Armen that is impossible to calibrate.
When I make the 4 point calibration, the X on the upper-right square is impossible to tap and when I make the 25 point calibration, the one in the middle is also impossible to tap too.
Before I started calibration the touchpanel worked quite good except for a little desviation, that's why I calibrated it but I lost the previous calibration and now it does what it wants.
I'm lost. What could be the problem or the solution? New drivers or what?
Hope someone can bring some light into it.
Thank you!
p.d. I made a search and found nothing about this.
Blanqui is offline   Reply With Quote
Sponsored Links
Old 09-10-2004, 07:40 PM   #2
My Photos: (0)
are you using a USB extension cable?
WhiteRabbit is offline   Reply With Quote
Old 09-11-2004, 06:46 AM   #3
My Photos: (0)
no, I'm not, I'm just using the usb cable that came with it.
Old 09-11-2004, 09:04 AM   #4
My Photos: (0)
I solved it!!!
I tryed to calibrate the touchpanel disassembled from the lcd and it worked.
Then I discovered that the touchpanel cable was going too near some high frequency cables inside the lcd case. I passed the cable through a different path and that was it. The touchpanel works again!
Hope this knowledge can help someone.
See you!
Old 09-11-2004, 12:38 PM   #5
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
Nice one! Some clever thinking.
Joa
JC-S60 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Lilliput 4-point and 25-point calibration? chris in nh LCD/Display 3 06-20-2004 01:16 AM
Lilliput-TS calibration lost! guvi Input Devices 12 04-15-2004 04:06 PM
touchscreen calibration.. screen edges offset mrzigzag Input Devices 0 04-12-2004 05:50 AM
Touchscreen Calibration.. How Long? AJ Quick Input Devices 4 01-04-2004 04:21 PM
touchscreen calibration is off ELEmental59437 LCD/Display 2 05-30-2003 01:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
