Go Back   MP3Car.com > Mp3Car Technical Hardware > Input Devices
Old 09-14-2004, 10:26 AM   #1
Paddymcc's Avatar
Paddymcc is on a distinguished road
Laptop Touchpad to PS2
How can i convert a touchpad from an old broken laptop i had to a PS2 connector?
the make of the touchpad is Synaptics model: TW1002M1
Paddymcc is offline   Reply With Quote
Old 09-15-2004, 04:32 AM   #2
mushin's Avatar
mushin is on a distinguished road
Most likely it already IS PS/2. The trick then is figuring out what the pinout on it is, and make a connector.
You should first see if you can find the info on the web. If you can't you might be able to figure out some pins, like power and ground, just by looking at the PCB, and simply try the data and clock in different combinations. That's what I did for a touchpad for which I couldn't find the pinout.
mushin is offline   Reply With Quote
Old 09-15-2004, 09:28 AM   #3
Custommx3's Avatar
Custommx3
I have one thats PS2
2007 Mazdaspeed 6
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Orinoco Gold
Custommx3 is offline   Reply With Quote
Old 09-15-2004, 09:57 AM   #4
Paddymcc's Avatar
Ive managed to get the wire soldered to the touchpad flat cable. Tricky to say the least with a couple of burnt finger tips But im getting there slowly but surely.
I still am unable to find a pin out diagram anywhere, even the synoptics site is no use.
Old 09-15-2004, 11:14 AM   #5
Tred is on a distinguished road
i want to do this as well. I found a tutorial on the web a while back. Cant seem to find it now. BUT, i was wondering, would we need specific drivers? Also how would we perform calibration and such?
Tred is offline   Reply With Quote
Old 09-15-2004, 11:20 AM   #6
Marsupial's Avatar
Marsupial is on a distinguished road
there should be a driver available for the laptop that would suit the device if it was already PS2...
-Mars
Marsupial is offline   Reply With Quote
Old 09-15-2004, 01:48 PM   #7
Paddymcc's Avatar
Right i've checked my PS2 cable and it has the following wires attached
(S2 Connection at back of Computer)
______________||____________
White Blue Red Yellow Black
+5 ? +5 ? -ve
I also have five wires coming from my Touchpad, anyone have a notion how i would go about attaching these to the above connections?
Old 09-16-2004, 01:43 AM   #8
mushin's Avatar
PS/2 has 6 pins. They are:
1: data
2: reserved
3: ground
4: +5V
5: clock
6: reserved
Your device might use the reserved pins, but you can safely ignore them and it'll still work fine. That leaves you with 4 pins you have to connect.
On the PC MB port, the pinout looks like:
_6__|__5
4_______3
__2__1
(sorry for the underscores, this blasted thing removes whitespace)
Now, your problem is you don't know the pinout on your touchpad. If you can't find it, your only real recourse is trial and error. What I did was solder connectors on all of the pins, so I can try different combinations quickly.
Some educated guessing can save you alot of trouble. Ground is probably the easiest to figure out by looking at the PCB, since many things tend to go to it. It's also the one you want to have right to make sure you don't damage anything - because the other pins operate at 5V, confusing them with power is probably ok, but who knows what reversing the voltage is going to do.
Tred: you don't need specific drivers for PS/2, though some devices might have special features that require them. Even then, it'll work fine as a generic device with the OS's built in drivers.
Old 09-16-2004, 06:21 PM   #9
nice, im gonna mess around with this today...
Old 09-30-2004, 10:55 AM   #10
F4kk3r0's Avatar
F4kk3r0 is on a distinguished road
You may want to read this :D that's how I did It
http://www.synaptics.com/decaf/utilities/ACF126.pdf
I also had a sparepart laptop and I ripped the touchpad for better use, that ofcourse is to put it in my Nissan.
LOL so the link takes you to interfacing guide.
F4kk3r0 is offline   Reply With Quote
Old 09-30-2004, 12:52 PM   #11
Dj_Aleks is on a distinguished road
i have one of those too..but mine is a TM1002SP...according to the guide, this should be a serial touchpad...now for the trick question...itīs ripped out of an Compaq Presario 1060...and has 4 additional CD player buttons added...Stop, Play, Fvd and Rev...the output from the touchpad has 8 connetors to the button PCB (yes, its a separate one) and from there i have another cable to the 4 additional buttons! so, its 1 touchpad, 1 central PCB where the mousekeys are located, and then thereīs another PCB for the additional buttons...now from the central PCB i have 10 wires coming out...and i cant find anything about it on synaptics homepage =/ anyone have an idea how to solve this?
Dj_Aleks is offline   Reply With Quote
Old 09-30-2004, 01:31 PM   #12
gibsonian is on a distinguished road
I have decided that I need to put a touchpad in the top of my console lid, towards the back. So people in the backseat can do stuff on the computer. They will probably just switch songs in the middle of the track to **** me off, but oh well. Maybe I will have it switched. Child lock on the touchpad. Yes, excellent..........
12.1 kiosk (screen separated), 99 gtp
gibsonian is offline   Reply With Quote
Old 09-30-2004, 04:19 PM   #13
the problem is i canīt figure out those f***ing pinouts! =/
Old 02-13-2006, 04:58 PM   #14
acpascini is on a distinguished road
Tm1002m6u
Someone have the pinout for the synaptics touchpad mouse ?????
i have one part and car pin it!!!
help!!!
acpascini is offline   Reply With Quote
Old 02-13-2006, 07:22 PM   #15
grimor2000's Avatar
grimor2000 is on a distinguished road
you do know that they make glidepad type mice already that are fairly cheap right?
Causa latet vis est notissima
VIA SP13000
1GB DDR400
Slimline Slot-load DVD-RW
60GB 2.5 Inch SATA 5400RPM
Dual Active PCI riser
PCI TV/FM card
Logisys FP800
Thermaltake VFD Media Lab
M1-ATX
grimor2000 is offline   Reply With Quote
Laptop remote on/off issue -- SOLVED: s2000 carputer skybolt General Hardware Discussion 17 09-20-2004 10:52 PM
FS: Infared Keyboard, PS2 touchpad mouse, USB FM transmitter bondbond55 Classified Archive 8 09-02-2004 12:05 AM
Shutdown/Startup Controller for laptop JoyRidun General Hardware Discussion 24 07-01-2004 06:08 PM
New to carputers. Old laptop + lilliput screen OK? NS98GSR Newbie 11 12-02-2003 07:29 AM
Wanted: touchpad & mini keyboard (ps2) Alives Classified Archive 0 02-04-2002 01:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
