The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Search this Thread Display Modes
Old 11-05-2004, 02:07 PM   #1
archimense's Avatar
Vehicle: 01' Audi S4 Twin Turbo / 00' VW Jetta VR6
My Photos: (0)
RF keyfob remotes for adhoc steering wheel controls?
I had a quick look and hadn't seen anyone mention this before...
I would like to have steering wheel controls for FrodoPlayer or MediaCar or whatever, and my car does not have existing steering wheel controls for me to hack into.
What I was thinking was using one or two RF keyfob remotes mounted on the steering wheel. These could be hooked up to the PC through the serial port, or through a microcontroller hooked up to the serial port.
I know you can get IR steering wheel controls, but then I would also need an IRMan or some sort of IR receiver for my PC. And I just think IR sucks... :P
Any opinions?
Here are some links...
http://momentumfire.com/RF_Remote_System.html
http://www.rfdigital.com/subcategory...b_Transmitters
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline   Reply With Quote
Sponsored Links
Old 11-05-2004, 03:11 PM   #2
Zac
Vehicle: 96 Volvo 850R
My Photos: (0)
You would need something to interface the output from the RF receiver to the PC.
You can search google/mp3car and find tons of parallel, serial, etc IO/relay boards, but I'd suggest USB and a search of the board shows Phidgets's USB stuff a popular way to interface. The outputs on the reciever would be tied into the inputs on this board. You can probally buy the reciever without the relays to save money...just hook em straight up using the pinout on the reciver's page.
The Phidgets part is:
http://www.phidgets.com/index.php?mo...121.111&IID=57
You can even add relays easily to it later if you decide you want to control other parts of your car via the carputer. There seems to be plenty of tutorials on their page describing how to use their parts.
Good luck with it....
Zac is offline   Reply With Quote
Old 11-05-2004, 04:26 PM   #3
archimense's Avatar
My Photos: (0)
Yeah I'm not too worried about interfacing to the PC. You could do it with just about any microcontroller.
I was really just wondering if anyone thought I was crazy for trying to do steering wheel controls this way.
Audi S4 Worklog
Old 11-05-2004, 04:49 PM   #4
HybridFox's Avatar
Vehicle: 1997 Ford f150
My Photos: (0)
no your not crazey
if i was you i'd leave comp at full blast all the time the get an in-line rotary volume knob. attach the knob to a small moter and then use the rf thing to control the moter
wa-la!
thats my quick fix of the day
-Lane
HybridFox is offline   Reply With Quote
Old 11-05-2004, 05:00 PM   #5
Naamanf's CarPC Specs
Naamanf's Avatar
Vehicle: 2007 Tahoe, 1979 Pontiac Trans Am, 1971 Hemi 'Cuda
My Photos: (0)
Or if you are really motivated you can buy an r/f remote, install micro switches into you steering wheel, and then connect them to the remote. I have seen it done a couple ways and if done right it can be pretty slick.
2007 Tahoe
Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
My Install
Naamanf is offline   Reply With Quote
Old 11-05-2004, 05:02 PM   #6
HybridFox's Avatar
My Photos: (0)
yes i assumed he was doing that (merely because its what i would do)
Old 11-05-2004, 05:12 PM   #7
e_z_street's Avatar
My Photos: (0)
Cool idea, I have SW controls for cruise control and don't want to mod those, but I would like to add extra buttons for pc control. I was thinking wired though.
e_z_street is offline   Reply With Quote
Old 11-05-2004, 06:04 PM   #8
HybridFox's Avatar
My Photos: (0)
hey yeah
i guess you could just wire up a switch trough your car bat to operate the moter(throw a rellay in there) saving some money and simplifying things
Old 11-05-2004, 06:57 PM   #9
archimense's Avatar
My Photos: (0)
My plan was to buy two remotes so I could have 8 buttons. Each remote would be on a seperate channel, and so I would also need two receivers. But that would total about $30 so no big deal.
Pull the remotes out of the casings, and hook in my own buttons that I could mount on the steering wheel. Then mount the actual rf transmitters at the back of the steering wheel, with the wires from the new buttons running to them. I want to wire up my own buttons because I don't like the button layouts of the cheap $15 keyfob remotes.
Then have use my old Basic Stamp 2 that I have lying around to interface with the two rf receviers. Then the Basic Stamp would be hooked up through serial to my PC. Then I could use Girder, or write some C++ in Windows to interpret whatever protocol I code the Basic Stamp to send to the PC serial port.
There may be cheaper ways to do this instead of getting two keyfob remotes and two receivers, but all of the other transmitters I've seen that aren't keyfob are too big for me to mount on my steering wheel.
Audi S4 Worklog
Old 11-09-2004, 08:28 PM   #10
Vehicle: 1991 Nissan 300zx
My Photos: (0)
Hmm this gives me an idea. I work at a custom motorcycle shop and switch housings for handlebar switches might be a very viable option for what you are looking for. They usually only have 3 switches on each side with one button larger or oriented differently than others(ie prev and skip). You could bolt them on the actual wheel of your or depending on your steering wheel one of the struts to the wheel. The housings can come in a variety of styles and colors(or chrome if thats your thing.) Note that like carpcs, very few things on a motorcycle are cheap. Stop by your local motorcycle shop and see what kind of switch housings they have or if they have any used ones.
Kefka_Killer.owns(you);
kefka_killer is offline   Reply With Quote
Sponsored Links
Old 11-09-2004, 08:44 PM   #11
My Photos: (0)
Ebay example of switch housing
Here's an example of some that can be had for pretty cheap, but they dont include the switches. Reflecting on the idea, the switches are of multiple types ie the start and horn buttons are momentary, the high/low beam switch and the run/engine off buttons are toggle, and i think the turn signals are also toggle.
Old 11-18-2004, 06:50 AM   #12
Cat Monkey's Avatar
Vehicle: 1997 115BHP Peugeot 406
My Photos: (0)
what the f**k??
why use rf? whats wrong with em lets say wire- your steerin column isn't going any where is it. this has been discussed. tis easy ,switches, usb-gameport and wire. now get to work and forget about rf keyfobs recievers motors pots it's not needed- just a game port.
Cat Monkey is offline   Reply With Quote
Old 11-18-2004, 06:56 AM   #13
Raw Wave
Vehicle: 1992 Ford XR2i
My Photos: (0)
Quote: Originally Posted by Cat Monkey
what the f**k??
I guess some didnt like the idea of having twisted wires when trying to do 3-point turnings.
Ricky327 is offline   Reply With Quote
Old 11-18-2004, 09:55 AM   #14
Cat Monkey's Avatar
My Photos: (0)
if you wire neatly (ie. through steering column not around) and with turning range in mind this is not a problem.
but on-wheel controls are passé anyway. pick up a stalk contoller. any stalk controller can be made work- 'tis easy
Old 11-18-2004, 02:10 PM   #15
archimense's Avatar
My Photos: (0)
Part of the great thing about this forum is the diversity of ideas.
If I don't want to have F**k*** wires wrapped inside of my steering column I won't!
Its pretty easy to critisize other people ideas, when you don't have any yourself.
Audi S4 Worklog
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Steering Wheel Controls god_of_cpu Input Devices 186 02-03-2008 03:33 AM
Steering wheel controls for FP ddogg_777 FrodoPlayer 4 07-22-2004 03:26 PM
Steering wheel remote controls... zummi Input Devices 15 07-19-2004 01:38 PM
Steering wheel controls Izik Input Devices 4 05-31-2004 09:46 AM
Keeping steering wheel controls with new HU pogue1000 General Hardware Discussion 4 01-14-2004 12:24 PM
Sponsored Links
Ad Management by RedTyger
