The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Search this Thread Display Modes
Old 11-26-2004, 02:32 AM   #16
Supermike's Avatar
Vehicle: 2000 Pathfinder
My Photos: (0)
Lopan, I was thinking the same thing as I was reading thru this post. It would be cool to be able to eliminate the mess of wires and connections when removing the PC for service. This would seem to be a perfect match for a casetronics c134 type case.
Could you list the digikey part numbers? Thanks.
"Protecting Privacy and Free Speech Online"
http://www.eff.org/
Supermike is offline   Reply With Quote
Sponsored Links
Old 11-27-2004, 02:18 PM   #17
LAME :)
lopan's CarPC Specs
lopan's Avatar
Vehicle: 2005 Pontiac GTO
My Photos: (0)
Yeah sorry it took so long to reply.... digikey part numbers are as follows
Male Connector Housing: Digikey Part Number H10109-ND
Male Pins for 24-28 awg wire: Up to 18 Digikey Part Number H10087-ND
Male Pins for 18-24 awg wire: 2 Digikey Part Number H10085-ND
Female Connector Housing: Digikey Part Number H10110-ND
Female Pins for 24-28 awg wire: Up to 18 Digikey part Number H10091-ND
Female Pins for 14-16 awg wire: 2 Digikey Part Number H10090-ND
Connectors have 2 spots for larger terminals, these are larger connectors and won't fit in the smaller spaces, you only need 2 if you plan on running power.
Female pins won't fit in the male connector housing and vice versa...
I tried to double check everything, but double check via digikey, when you look up the connector housing, digikey lists what goes with them so double check, or if you want a different guage connector. Also, there are pictures of each connector (how I figured out the difference between the big and small pin connectors)
Also, if you want a 40 pin connector instead of a 20 pin....
Male Connector housing: Digikey part number H10101-ND
Female Connector Housing: Digikey part number H10102-ND
These use the same pins as above... Looks like 4 spaces for the larger pins... but could be wrong...
Also forgot to mention... Mines done, touch screen, video in's, vga, everything works like a champ...
lopan is offline   Reply With Quote
Old 11-27-2004, 02:34 PM   #18
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2007 Renault Megane
My Photos: (9)
Pics, pics....
Cris is offline   Reply With Quote
Old 11-27-2004, 03:25 PM   #19
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
it kinda looks the same as it does in the first set of pics... only it comes on now?
Ok, Ok, here it is with my neato "ebay special" night vision backup camera... kinda cool, the last picture is where I turned the flash on the camera off, and the ir emitters on the night vision camera is lighting me up
Old 11-27-2004, 07:52 PM   #20
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (9)
Nice work man. That's a pretty big camera. Where are you going to mount it?
Sponsored Links
Old 11-27-2004, 07:56 PM   #21
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
Dunno... it's bigger then I expected, being that it's all going into a 68 scout... I'll probably mount a trailer hitch deal, and put it in a trailer hitch cover or something.... Don't know, it senses darkness and all those lights glow red which I might not want visible...
Old 11-27-2004, 08:02 PM   #22
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
thats a very cool setup, love that camera, have to get one to play with.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-27-2004, 08:23 PM   #23
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
the camera is kinda cool, it's advertised as color/night vision, which it kind of does... kind of... when lights are, the color is screwy at best, a little too much blue or just weird... when the lights go out, a daylight sensor kicks on the IR emitters and it's kind of obvious whats happening with the color, although I can't really explain, it kind of looks like when the lights are on it's in a partial IR mode, which causes funkiness with the color? still it's a cool little camera and worth the 50 bucks I paid for it... so we'll see how it works in a real world application
Old 11-27-2004, 08:38 PM   #24
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
Man that turned out awesome. Good idea and well done
antimatter is offline   Reply With Quote
Old 11-30-2004, 06:13 PM   #25
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (9)
Could you please post a pic of the car: 1968 International.
Old 11-30-2004, 10:23 PM   #26
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
Here ya go.... my baby...
Still haven't got a clue as to how I'm going to do an install in this beast... but I'll make it happen.
Old 11-30-2004, 10:27 PM   #27
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
Here's the interior...
Old 11-30-2004, 10:34 PM   #28
LAME :)
lopan's CarPC Specs
lopan's Avatar
My Photos: (0)
One more... here it is with the hardtop...
Old 12-01-2004, 12:22 AM   #29
Vehicle: '91/Honda/Civic
My Photos: (0)
*brain fart*
I've been looking at this thread for awhile and must say that it is a great idea. After waiting for a week and a half, I finally received my Starvision TS monitor and it's the same exact monitor. I know, others have said this in other threads, that the Lilli and Starvision are the same monitors.
Since both of these are identical, they use the same stand as well. You might be able to use a spring to exert pressure against the knob used to turn the screw for mounting the monitor. This way, you can easily remove the monitor by pressing on the knob and lifting the monitor up. To install, press on the knob and slide the monitor down.
Again, this idea will only work if you can get a spring that can exert a good amount of pressure between the plate and knob and won't be too stiff to compress. It might be possible to get rid of the knob altogether and use a square nut and bolt with an appropriate spring(valve spring?) to accomplish the same thing.
DRWeside is offline   Reply With Quote
Old 12-01-2004, 08:25 AM   #30
Tainted Love
Cris's CarPC Specs
Cris's Avatar
My Photos: (9)
You must've done some serious work on that "beast"...it look awesome...plenty of room for a carputer.
Some tehnical specs please...
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 114 07-29-2008 03:08 PM
epia m10k + lilliput => gps blocker? NaFooEsi GPS 28 04-12-2008 08:53 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 08:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Sponsored Links
Ad Management by RedTyger
