Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 06-15-2005, 03:55 PM   #196
jbors's Avatar
jbors is on a distinguished road
I'd love to have some news, but not yet. I'm pretty swamped with VW/BMW adapter.
Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
Old 06-15-2005, 04:23 PM   #197
ScrapMaker is on a distinguished road
do you think it will cost approximately the same as the alpine cable, or is there something extraordinarly different about the IP-Bus interface?
ScrapMaker is offline   Reply With Quote
Old 06-15-2005, 07:39 PM   #198
AdReNaLiN is on a distinguished road
Is there something I can do to help with AI-Net?
MPr3Lude!
AdReNaLiN is offline   Reply With Quote
Old 06-15-2005, 09:42 PM   #199
jbors's Avatar
I cannot do it right now even though I have all the info, it just takes time.
Sorry for that.
Car mediacenter
Old 06-23-2005, 03:21 PM   #200
Default is on a distinguished road
Quote: Originally Posted by jbors
M-Bus is on sale now. So it is ready. See the first post. For MBus audio come directly from either 3.5'' jask or 2 RCA into DIN8C just let me know which one you need.
If you can start with AiNet please don't forget about check sum algorithm and its high speed.
As of RS232 I want to see the PC knowing what changer it connected to. This way USB is more flexible.
I don't see any reference of it on your website. Is it still available? Do you have HONDA/ACURA connector "edition"?
Default is offline   Reply With Quote
Old 06-24-2005, 12:46 AM   #201
PredatorCoder is on a distinguished road
Simple M-Bus Aux In?
I do not have a car computer and all I have is an MP3 player (actually a Pocket PC). I have a 1996 Honda Civic with factory head unit and factory tape deck. After a little googling I have discovered that this uses M-Bus - in fact it is the same except that the plug has two pins switched to encourage users to buy Honda equipment and not Alpine equipment (more $$$ for dealer). It is an 8 pin circular DIN connector, you can see it at http://carstereohelp.net/images/Wire...sHon121001.jpg
As I said I don't have a car computer. So there's no point in using complicated USB chip as mentioned earlier in this thread. All I want to do is have the head unit detect presence of "CD player" (the MP3 player) (and thus start playing audio from it).
Connecting the three audio pins to a 3.5 mm audio connector seems obvious. But I don't know what's required in getting the head unit to start playing audio from these audio pins. Do I have to use a simple resistor or something? Is something more elaborate required?
Basically: how to get auxiliary input into M-Bus input port with as little equipment as possible?
Thanks in advance for any help.
PredatorCoder is offline   Reply With Quote
Old 06-24-2005, 01:56 AM   #202
jbors's Avatar
You can use "simple" AUX adapter. I'm not aware of any other simple way of getting AUX to work. MBus protocol very demanding to a sequence from CDC.
Hope this helps.
Car mediacenter
Old 06-24-2005, 12:44 PM   #203
How to build AUX adapter?
Right, but how might you go about building "simple" AUX adapter? Is it fairly simple (e.g. a resistor, if that) or do you have to do something more complicated?
Also, the head unit is from 1996 Honda Civic. Is there any chance it would use AI-Net instead of M-Bus, or would the unit be too old for this? It's a very simple head unit and all it can do is switch CDs in the CD changer and move between tracks. It tells you basic track information (track count, probably length). It's really simple.
Old 06-24-2005, 05:03 PM   #204
jbors's Avatar
You may try to play with it. As far as I know there is _no_ simple resistor that works for MBus. It has to be a certain sequence you send to HU.
Car mediacenter
Old 06-28-2005, 10:54 AM   #205
any updates on ip-bus?
man, you are going to be filthy rich, very soon.
Old 06-29-2005, 03:00 AM   #206
DJ-Q is on a distinguished road
yeah I second Ip-bus
again....
DJ-Q is offline   Reply With Quote
Old 06-29-2005, 11:08 AM   #207
jbors's Avatar
Sorry. really busy with VAG adapters now. I will work on that for sure. Cannot just say when...
Car mediacenter
Old 06-29-2005, 02:04 PM   #208
lagunatl2k is on a distinguished road
Can't wait till the ip-bus adapter is done thanks for all your hard work
lagunatl2k is offline   Reply With Quote
Old 07-01-2005, 09:26 AM   #209
odin836's Avatar
odin836
The IP Bus will be great, keep up the awesome work...
odin836 is offline   Reply With Quote
Old 07-06-2005, 10:54 AM   #210
I will sell you my soul for one of these convertors.
/ip-bus, that is
External PC Card adapter for Verizon BroadbandAccess Bluebisz Wireless Communications 7 02-24-2005 10:11 AM
cd changer control to control the pc babas151 General Hardware Discussion 6 10-26-2004 12:21 AM
cd changer hack meyer64 General Hardware Discussion 13 08-25-2003 01:01 AM
Cig lighter adapter to power PC? Alphared General Hardware Discussion 5 08-03-2003 10:14 AM
