Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 12-09-2004, 08:28 PM   #1
CowPuter is on a distinguished road
replacing 8" Lilliput touchscreen
Hi;
I've damaged my touchscreen panel. It occured after I absent-mindedly used the stylus to rub away some miniscule silicone streaks on the extreme edge of the touchscreen. As a result, if you run the stylus along the top edge of the screen, the cursor veers along the screen in tooth shaped pattern - down/up.
I've tried to recalibrate both methods, but the panel is having none of it.
In addition, I managed to inflate the plastic cover off the screen about 3/4 of an inch (the minicomputer I'm building is a sealed waterproof one, cooled by convection - not for in-car use!). I'd forgotten to install the pressure relief before leaving it on for a day as a temperature test, and the only relief was for expanding air to squeeze through the foam mounting tape between the plastic and touchscreen and the silicone seal. Piling a few books on it for a day squashed it back down, and it worked fine... until the silicone incident.
Soooo... where do I get a replacement panel (don't need controller, just the glass bit)? Comments?
CowPuter
CowPuter is offline   Reply With Quote
Old 12-27-2004, 04:14 PM   #2
update
Armen emailed me the answer... posted fyi.
"You will need a panel from this kit: http://digitalww.com/8TSK.htm
Currently they are out of stock but I will be getting some more ... Check back on the website and place your order when you see that the kit are IN STOCK.
This is going to be the same panel as you have so it will be a direct replacement."
Cowputer
Old 12-27-2004, 04:31 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
sweet!
glad he could get you all taken care of!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-28-2004, 03:53 PM   #4
_dopehead_ is on a distinguished road
i broke mine even before i got it monted in the car, and got the TSK from digitalww as well, easy to replace worked like a charm.
Jan
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Old 12-28-2004, 10:42 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
This gut is selling one...
http://www.mp3car.com/vbulletin/classified-archive/39042-sale-touchscreen-lilliput-8-xga-display.html
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
8" Lilliput Touchscreen Info Mrbmw99 LCD/Display 11 12-13-2004 02:31 PM
Lilliput 7" touchscreen VGA LCD or 8" ? What would you get ? civichatch LCD/Display 7 11-19-2004 12:32 PM
Lilliput 8" Touchscreen Jimbo1978 LCD/Display 3 08-30-2004 10:11 AM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 10:47 PM
Lilliput 8" Touchscreen Display Randomtask LCD/Display 6 02-06-2004 02:12 PM
