Like JW said, you best bet is find the pinouts, then it's a simple matter of wiring them up to a PS2 connector. Lacking a pinout diagram... you can still figure it out, but it's considerably more iffy. You can try trial and error, which is what I did with another touchpad (you can check it out in the thread "Cheap Touchpads"), but the one I was working with had only 6 pins, and I deduced the power and ground pins from the PCB, so I was trying to guess two pins out of the remaining four, a much easier task. I wouldn't go this route unless you can similarly figure out vcc/ground, since the combinatorics get rather out of hand.
You could also use a o-scope to make the task easier, but I'm guessing you probably don't have access to one so I won't go into details.
